-   -   2017 22fb thermostat (http://www.airforums.com/forums/f295/2017-22fb-thermostat-160505.html)
No1up 12-14-2016 02:46 PM
Anyone know how to use the thermostat? I have to run the ac on all the time because I don't know how to engage the thermostat... 😤
alumdreams 12-14-2016 03:32 PM
I have a 2016, but I think it's the same as the 2017. The Mode button will let you cycle through the various modes (Fan Only, A/C, Heat Pump, Furnace, Off). Additionally, there is a power button (looks like a circle with a line partially through it) that will let you turn the whole unit off as well.
Rpatrick16 12-14-2016 07:04 PM
I'm not quite clear what you mean by "thermostats". That sounds crazy...doesn't it. So let me answer "what I think your asking". The thermostat located on the wall next to the TV only controls the "heat/furnace". It is NOT associated with the AC/Heat Pump located on the roof of the coach. The controls for "heat or AC" are color coded. Actually you can run the "furnace" and the "ceiling heat pump" at the same time. HOWEVER, you must be connected to "30 AM shore power" or at least a "3000 Watt or higher generator" to operate it.
No1up 12-14-2016 08:18 PM
Where might I find the mode button? :)
Frank&Mike 12-14-2016 08:21 PM
I think you're asking a question similar to one I had ...
We previously owned a 22 ft. Sport. One of my complaints was that the air conditioner ran only in continuous mode or off. It doesn't function like the units on most other Airstreams.
Following is a thread I had inquiring what would be involved to install a different thermostat which would allow the unit to cycle on or off when the desired temp is reached:
http://www.airforums.com/forums/f427...rt-131589.html
Unfortunately ... the 22 ft. Sport air conditioning unit doesn't allow the unit to cycle on or off on it's own ... it's either on or off.
ohmman 12-14-2016 08:28 PM
So to understand, the choice is that it just keeps blowing continuously or it doesn't blow at all? I'm taking delivery of mine next week and that's slightly disconcerting. Can one at least adjust fan speed? Does the compressor stay on the entire time?
I would have to imagine it's able to be rigged up, but from my research here, Frank&Mike would not be afraid to tackle such a thing. So if that's the word, it's slightly disappointing.
No1up 12-14-2016 08:46 PM
So what's the thermostat for? Lol
Frank&Mike 12-14-2016 08:51 PM
Don't Let Me Discourage You ...
Don't let my reply discourage you with your upcoming purchase ... but that's how ours operated ... it was continuous blow or no blow at all ... the fan speed could be adjusted though ... maybe they have upgraded the units since ours ... ours was a 2015 22 ft. Sport. I will admit however this is one of the primary factors in our decision to sell the 22 ft. Sport and return to a larger Airstream.
ohmman 12-14-2016 09:23 PM
Well, I have no other option at this point, as my TV is a Tesla and the 22 has the right frontal area and weight profile. I'll rig it if I need to do so. I've completely automated my homes for the last couple of decades, so I have plenty of "rigging it up" experience. Easiest would be to attach an external thermostat to a dry relay, and leave the AC switch on. When the thermostat turned on, the relay would turn on, and the AC would run. Then, back off. I'm sure there are better solutions but that's the first quick one that comes to mind.
Piggy Bank 12-14-2016 09:41 PM
The ceiling mounted AC unit is a very basic type of unit. It is not controlled be a thermostat like your house. More like a PTAC unit like in a hotel.
When in use, it is on. You can set the fan lower or higher, and the temperature lower or higher. The temperature setting will control the compressor coming on, running for a bit, and then turning off. It works fine, but it's not fancy. It can also run fan only, or with an electric heat option. But if this appliance is being used, it is on and blowing. It works just fine, and is fairly straightforward.
There is also a propane furnace in the Sport 22. It is controlled by a wall thermostat on the wall by the refrigerator. It works more like a home furnace. The blower comes on, the burners light, the space warms, the thermostat is satisfied ,and it all turns off until the temperature lowers so that the thermostat kicks it all on again.
Oh, and FYI I don't believe standard 24v controls will work on these systems, so you may be doing a bit of gerryrigging to try out your ideas.
ohmman 12-14-2016 10:35 PM
Thanks very much for the detail and information. Regarding the above, the dry contact should remove the need for voltage requirements. I can run a standard thermostat with dry contact off of the 120V AC supply (I won't be running AC if I'm not connected to my 30A, so the 120V should be active), and that dry contact isn't voltage dependent. It's like clipping a wire, then putting it back together. But I won't know for sure until I get it.
Again, I appreciate you sharing your knowledge of this coach.
Piggy Bank 12-15-2016 06:28 AM
Happy to help. I am also not sure if the AC unit is using any type of temperature controls with set points for the compressor or just a timer. So that may also be a consideration to explore.
Also to clarify from some of the earlier posts, the sport 22 is an AC with electric heat strip. It is not a heat pump (no reverse cycle).
Boxite 12-24-2016 12:58 AM
The AC unit thermostat works on temperature but is fairly crude. All it does is control the compressor. The blower will run continuously. I don't find that bad at all, as it keeps the place ventilated and avoids mold growth.
The furnace will cycle on/off including the fan. However, the small lever which switches the unit on or off is incredibly stiff to operate. You'll think you're going to break something to get it to the ON or OFF position, ...while the temperature control on the bottom is very sensitive. Once you find the spot where you like the temperature...leave it alone.
At least that's the way we work it.
We also carry a small electric heater with a fan that we use in the bathroom and as a backup should the furnace fail. Although the furnace is ducted to the bathroom... the lack of duct insulation and distance of that duct results in cool air blowing into the bath area.
iAirstream 08-13-2017 10:13 AM
Airstream 22fb vs Rockwood Hard side High wall A214HW
2018 Airstream 22fb Price: $55,909
-Bed length - 78"
-Thermostat for Air conditioning: NO
2018 Hard side High wall A214HW (A-Frame pop-up) Price: $14,495.00
-Bed Length 80"
-Thermostat for Air Conditioning: YES
My house, my $50,00 car and my $13,000 A-Frame Popup has Thermostats for Air Conditioning. Pay for a $55,000 Air Stream with no climate control, I don't think so.
It's a deal breaker. The largest or one of the largest Airstream dealers said, "Airstream will never put a Thermostat in their 16 and 22 sport models." So, that means I will never buy one. When I visited my local Airstream dealer on August 12, 2017, I could not believe that Airstream still hasn't done this. Even my 2009 VW Jetta Wagon had Climate control. Maybe the 2019 models will have this. According to my local Airstream dealer, Airstream does this to force first time buyers to quickly upgrade when they realize this problem.
This firmly puts Airstream in the low quality category. I was ready to buy one, I was looking forward to it. Now I know that will never happen. I am very disappointed.
waninae39 08-22-2017 09:45 PM
we put a std home model AC/heat digital thermostat in our sport 22FB. it only controls the heat of course
it runs off a battery and has the controls to work the furnace
no issues in the last 3 months
