-   1984-1988 Limited (http://www.airforums.com/forums/f279/)
-   -   Zip Dee awning (http://www.airforums.com/forums/f279/zip-dee-awning-159138.html)
Daddyo_1 11-05-2016 11:36 AM
Zip Dee awning
So I have a few threads going and thought it best to separate my topics. My zip dee will not retract. It seems to be frozen on the forward side and I'm afraid I'm going to break it if I force it. Any suggestions?
Chatooga11 11-05-2016 01:10 PM
Hey Daddyo,
Just had to say it. Your spring inside of your awning may have broken. If that is, in fact, the problem it is an easy fix. Zip Dee will send you a spring ad they are not expensive. Installation is DIY.
HiHoAgRV 11-05-2016 01:55 PM
Attachment 274840
Does your awning have the little locking arm like mine? The small curved lever with the hole in the end?
BigAl 11-05-2016 04:59 PM
What Hiho refers to is a Z-lock. It is intended to lock the awning in the closed position.
If it is locked while the awning is open it will not roll up.
Also Zip Dee says not to lock the awning when in use.
Al
Daddyo_1 11-06-2016 12:57 PM
Originally Posted by HiHoAgRV (Post 1873047)
Attachment 274840
Yes it does, I pulled it down before trying to pull it out, but it seems to still be in the locked position. The awning will only move about an inch or two
Daddyo_1 11-06-2016 01:05 PM
Attachment 274909
