-   Full-Timing (http://www.airforums.com/forums/f314/)
-   -   Travel size Wireless All-In-one Printer (http://www.airforums.com/forums/f314/travel-size-wireless-all-in-one-printer-155431.html)
Re-Pete 08-17-2016 06:27 PM
So, we're spending as much or more time in our AS "Earthship" as we do in our Sticks & Bricks. Not to mention that our plan is to sell the house next spring. If all goes well we've already got a buyer.
Our All-In-One Epson printer crapped out a few days and we need a new one ASAP. The wife said, "Get one that is small enough to travel with us".
Any suggestions.
moosetags 08-17-2016 06:43 PM
We run an Internet business out of our Airstream when on the road (we are half timers). we use the the print, copy, and scan functions on a daily basis. we went through several printers over the years.
Our most recent printers have been HP's in the 4500 and 5500 series. We find that these are very durable and small enough to fit in one of the overhead cabinets. They feed paper from the bottom which is necessary for cabinet use. They do a good job, are relatively inexpensive, and use the less expensive #61 ink cartridges.
Brian
Re-Pete 08-18-2016 07:42 AM
Thanks, I'll check them out.
OTRA15 08-18-2016 08:07 AM
I have always preferred Epson over HP, for the separate color cartridges. We found that print tasks which include a lot of one color (blue for instance for URLs etc.), will chew up the HP tri-color cartridges pretty quickly. Not sure what Epson makes in a small multi-function machine, but our current Epson printer has survived many construction site accidental droppings, all kinds of dust, and keeps on printing. Remarkable for a cheap basic unit, really, in retrospect.
Let us know what you find please, Re-Pete.
Peter
PS -- FYI other threads worth a check IMO:
http://www.airforums.com/forums/f42/...ad-144998.html
http://www.airforums.com/forums/f451...ons-93834.html
http://www.airforums.com/forums/f42/...er-111944.html
http://www.airforums.com/forums/f317...rs-147699.html
richw46 08-18-2016 01:24 PM
Any suggestions.
I use an HP Envy 5530 that I can put in the front left overhead bin. I use a wired connection because I'm pretty sure wireless would go over the Verizon Jetpack and use up data. It can scan and copy too, scanning uses data to email, haven't tried scanning with the cable yet.
I have to put some wood blocks to lift it up for the front loading paper tray but it's not a problem. I have to run an extension cord along the wall to power it. Mostly I use the black only cartridge, using color only when necessary. Draft mode in black in does 90% of what I need.
Goal15 08-18-2016 01:25 PM
Originally Posted by Bev1940 (Post 1837158)
I have never been banned from a campground with my AS, when they ask me I just tell them 31' Airstream and they never ask the year !
Yes but do they want to inspect your All-In-One printer?
fth 08-18-2016 01:26 PM
I'm interested in this too.
CalifBob 08-18-2016 01:56 PM
Travel Printer
I have an HP Officejet 150 All-in-One. It is incredibly compact - fits in one of the small narrow cupboards, uses regular HP cartdriges - inexpensive on eBay, is battery powered when needed and scans documents. It works on bluetooth or wireless with a laptop. It will print in high-quality and you can get a photo cartridge for it. I bought mine new on eBay and paid less than half retial for it. I had the older model before this and it worked well for over 3 years. A lot of business people use these in the field with a laptop so it's made for rugged use.
Jekerrville 08-18-2016 03:55 PM
Ditto on HP 150 A-in-One
Ours fits in forward overhead bin with Blu-Ray and AT&T router, Fire unit and WD EZ2 Cloud unit. AC power is available there, but all thd gear is either 12 VDC or 9 VDC.
HP ENVY 150 has worked remarkably well and allows you to turn off color so you don't burn up ink.
Bluetooth talks directly to laptop and Iphones so printing is a breeze. Envelope printing is easy as well.
It is not a production printer. But for most needs has done well.
Good luck
OTRA15 08-18-2016 05:29 PM
Good to know, thanks Jekkerville and CalifBob for the lead. And welcome to the forum! This looks like the current available model:
https://www.amazon.com/HP-OJ-150-Mob.../dp/B0076O2BRI
Unless I missed something, this model does not have a scan function?
Like this 5540 does?
https://www.amazon.com/HP-Wireless-P...ents=p_89%3AHP
Peter
Re-Pete 08-18-2016 09:17 PM
Thanks, everyone. Some good leads here. I will check them all out. Space is the main issue. Anything new we add means something else that's less useful gets left along the road somewhere. I'm trying to do a good job here so that something isn't me. :angel: I gotta say, I do like Epson for the individual color cartridges, but I'm going to be open minded and check every recommendation before I pull the trigger.
OTRA15 08-19-2016 04:47 AM
Thanks Pete. One correction to Post # 10 -- the HP 150 mobile unit does have a scan function, but the price of over $333 seems like one is paying a premium for the small size convenience? The ability to turn off the color would work for us (to spare the tri-color cartridge). Overall size might govern the decision -- TBD
Thanks again for this thread.
Peter
PS -- Data sheet for the HP 150:
https://images-na.ssl-images-amazon....ile_CN550A.pdf
Dimensions in middle of right column -- pretty small!
WxDxH: 13.98 x 6.95 x 3.52 inches -- weighs 6.4 lbs.
Al and Missy 08-19-2016 07:51 AM
Not what you asked, but I went with a small laser printer because with infrequent use I was concerned ink cartridges would dry out. I would like to have had an all in one but couldn't find one small enough to fit in one of our cabinets.
Al
NY24 08-19-2016 08:23 AM
Good information!
