-   Our Community (http://www.airforums.com/forums/f48/)
-   -   LED's flickering. (http://www.airforums.com/forums/f48/leds-flickering-155022.html)
bgates55 08-09-2016 04:22 PM
LED's flickering.
Help, replaced all 12 volt lamps with led 12 vdc. They start flickering. Thought it was because of the inverter. Checked it out, everything seems ok, out put voltage is between 13.2 to 14 vdc. At 1 lamp I am getting 13.7 vdc & 38.6 vac??? Don't understand that. Has anyone have a clue what is going on? I have a vintage, 77 model avion.
Anything would help. Thanks in advance.
overlander63 08-09-2016 04:30 PM
If you have the inverter output connected to the 12 volt system, I could see why the lights are flickering. I'm surprised they haven't blown out from the 120 volt output.
HowieE 08-09-2016 07:15 PM
Sounds like you have a very dirt power supply. Try shutting the power supply off and see what happens with just the batteries.
bgates55 08-10-2016 02:27 AM
With no ac hooked up ,same results. That's what is puzzled me.
mccrosti 08-10-2016 05:53 AM
I'd start at the beginning. Did you do the work yourself, if so did you change any wiring. Most of the 12 volt is daisy chained. Next replace a bulb or two see if it still flickers.
HowieE 08-10-2016 08:14 AM
I think the choice now is to remove, test, and replace one bulb at a time. This will yell if one of the bulbs has a problem that may be effecting other down stream.
I have had one section of an LED ribbon strip start to flicker but it did not effect the rest of the strip
mcomeaux 08-10-2016 08:34 AM
Flickering Lights
Do all the lights flicker or is isolated either in front or rear inside coach?
