-   -   1976 Overlander compartment door seal replacement (http://www.airforums.com/forums/f164/1976-overlander-compartment-door-seal-replacement-153718.html)
flothunissen 07-13-2016 08:38 PM
We are in the process of replacing all our compartment doors seals.
I am a little confuse on how to do that and which seal I should use.
The picture I attached below is the seal that was recommended on a airstream supply website.
Now, is the seal should be glued around the door frame or on the inside frame?
If someone could send me a picture that would be perfect. We have a Airstream from 1976, Overlander 27 feet.
Thank you for your help.
