-   -   Rock Guard Window. Wanted. Sovereign 21' (http://www.airforums.com/forums/f164/rock-guard-window-wanted-sovereign-21-a-151778.html)
tjansen 06-03-2016 10:25 PM
I have a broken Window Rock Guard. This is the one piece unit. 1995 Sovereign 21' The frame is in good shape , The Lexan? is cracked top to bottom R side. There is a total unit at http://odmrv.com/catalog/index.php?m...roducts_id=191 It is $375 and $145 shipping . I live in Denver and wonder if there is anything local I can get?
Tom
teamhaney 06-24-2016 11:23 AM
Is it repairable?
Can you source a piece of Lexan locally and put it in the frame you have? A piece that size would run about $100.
tjansen 06-25-2016 10:39 AM
I will look locally. The existing window cover goes edge to edge and covers the wrap side window. Does Lexan bend ? easily? or does it need heat ? From what little I have used Lexan it is TOUGH and does not lend to bending. Thanks for your input teamhaney.
teamhaney 06-27-2016 08:14 AM
I've read you need to carefully heat both sides of Lexan to bend it. Heat gun works best. Propane torch would too but not as controllable. Leave the protective coat on while heating. Experiment on a scrap piece first.
Sent from my iPod touch using Airstream Forums
