-   -   Reconfiguring baggage hatch door (http://www.airforums.com/forums/f164/reconfiguring-baggage-hatch-door-151174.html)
RankAm 05-23-2016 08:54 AM
I am cross posting from here about redoing a baggage hatch door to change from a "J" hinge (on the top or bottom) to a piano hinge along the side of the door.
Any advice would be appreciated.
Thanks, Hank
Aerowood 05-23-2016 09:30 AM
What kind of hinge are you planning on using? I would recommend this in aluminum
http://www.mcmaster.com/#piano-hinges/=12jbpqk
RankAm 05-23-2016 11:16 AM
Thanks. That is exactly what I ordered.
I intend to install a c channel behind the hatch frame to which the piano hinge would attach. Any concerns about adequate support?
Hank
Aerowood 05-23-2016 11:42 AM
That should do it
RankAm 05-24-2016 08:02 AM
Thanks, Kip, for your advice.
Hank
Greg1410 05-24-2016 08:35 AM
Thanks for the info - I plan on doing the same. What size pin diameter would you recommend? Also, unfinished or anodized?
Greg
Aerowood 05-24-2016 09:23 AM
3/32 to 1/8 bare. I also prefer the Mil Spec hinge but it may be cost prohibitive for most people. It is an extruded hinge vs rolled hinge, extruded is far superior to rolled.
RankAm 05-24-2016 06:14 PM
I am finished (for now) with the new hinge installation. See here.
Hank
