-   -   nx awning operation (http://www.airforums.com/forums/f164/nx-awning-operation-149888.html)
whitegs 04-26-2016 10:03 AM
nx awning operation
I am trying to follow the directions about opening the patio awning and raising it so that i can open the door. If I get to the last step the tension on the awning is so high I can't pull the pin to raise the awning. If I first raise the awning, I find I'm not tall enough to push the awning up and out to extend the arm so I need to use a ladder which is precarious pushing against the tension on the awning. So what i've done is first raise the awning and then put on the tension arm. If I do that, on one side I can't really extend the tension arm because everything is so tight.
I feel so inadequate :mad:
any suggestions?
Inland RV Center, In 04-26-2016 10:11 AM
any suggestions?
There is "nylon wheel" available that mounts on the top of the door. That eliminates the awning problem.
And it's cheap too.
AWCHIEF 04-26-2016 10:18 AM
ZD makes assist handles. Check their web site.
AWCHIEF 04-27-2016 07:32 AM
These might help
http://awningsbyzipdee.com/3801.html
