-   -   82' Airstream 310 Motorhome - Need Help (http://www.airforums.com/forums/f159/82-airstream-310-motorhome-need-help-149150.html)
Bamaforlife 04-11-2016 05:46 AM
i have an 82' Airstream 310 with a blown Isuzu 6BD1T engine in Memphis Tennessee that i need to either transport to Greensboro NC to have repaired or find a diesel shop near Memphis that can do engine replacement - any suggestions?
Attachment 260420
mayco 04-11-2016 06:03 AM
Are you absolutely sure the motor is "blown"?? Typically on these Isuzu 6bd1 motors, they are ruined only by one of two things; running without oil or a severe overheat.
Bamaforlife 04-11-2016 06:53 AM
310 engine blown
I have been told it threw a rod and the engine needs a full rebuild[ATTACH]Attachment 260435[/ATTACH]
chiefair 04-11-2016 07:30 AM
If your motor is not salvageable you should check out this eBay posting:
http://www.ebay.com/itm/1983-AIRSTREAM-310-MOTORHOME-DRIVER-SIDEFRONT-WINDSHIELD-WIPER-ARM-L-K-/151936080689?hash=item2360189b31:g:ZkcAAOSwFqJWh0r H&vxp=mtr[/url]
He lists a motor among his 310 parts for sale.
You can see a picture of my 310 (also with a blown motor) being transported on page 4 of this thread:
http://www.airforums.com/forums/f311...-139118-4.html
Good luck!
mayco 04-11-2016 07:50 AM
Ouch!!!!!
Isuzusweet 04-26-2016 09:01 PM
@Bamaforlife
Sorry for your luck. As I live in Canada I can't help you with your search but I do wish you all the best.
Mayco and I have the same motor and any info would be helpful.
Did the mechanic give you any possible cause? Bad oil, wrong oil?
What kind of mileage did you have on the motor?
It looks like it spun a bearing versus throwing a rod. If it's just a bearing then the block should be fine; or not? Is the block salvageable?
Cheers
Tony
