-   -   Replacement breaker box (http://www.airforums.com/forums/f37/replacement-breaker-box-148841.html)
Wayne1344 04-05-2016 11:17 AM
I have a 88 excella 1000 34 ft trailer that I need to replace the breaker box that is where the shore power enters at. Any ideas on a item number or model that works well? Thanks
sgschwend 04-05-2016 08:50 PM
A picture might help.
I installed a new Square D box in my 1986. I did not like the breaker used in the original. They would connect but there wasn't much hold power to keep them seated.
Something like this model: Model # HOM612L100SCP, it is a main lug panel.
I used a six breaker box. One breaker is used for the main breaker and it is wired as a back feed to the panel. The result is you have a main disconnecting breaker (30 Amp).
If I remember correctly I have four other 20 Amp breakers, one of which is dedicated to the AC unit.
