-   -   Finally... What to do with the sink cover (http://www.airforums.com/forums/f46/finally-what-to-do-with-the-sink-cover-148726.html)
RFP 04-02-2016 04:14 PM
Even though we've had our new-to-us 23D International Serenity for only a short time, we already discovered that we didn't know what to do with the round sink cover when we needed the sink, well, uncovered...
Found a 'robe hook' that works perfectly, and it matches the Grohe kitchen faucet perfectly. It only protrudes 1 5/8" from the cabinet, much less than it looks in the photo.
Under twenty bucks and this little 'problem' is solved!
Check it out here: http://www.amazon.com/Hansgrohe-4051...ilpage_o02_s00
Rob
AWCHIEF 04-02-2016 04:31 PM
I just stick mine under the couch cushion. Out if site out of mind until needed.
Al - K4GLU 04-02-2016 04:35 PM
I lay mine on the couch. Doesn't cost anything.
M. Smith 04-02-2016 04:38 PM
Very nice looking. Mine just stays under the sink since I keep a plastic tub in the sink most of the time.
Mrjkq 04-02-2016 04:52 PM
Under the bed!
moosetags 04-02-2016 04:56 PM
That little hook is a neat idea. We have never found a use for it, so ours is stored along with the original bedspreads in a closet somewhere in the house.
Brian
switz 04-02-2016 06:18 PM
We put a flip up shelf beside the sink in our 2015 23D with a hickory surface to match the hickory dinette table top. Both the solar charge controller display along with the Magnum controller display and the ship's clock have been mounted on hickory panels. We also have a hickory panel for the new circuit breaker box below the refrigerator. We installed a key hook strip below the flip up side table.
The sink frisbee is stored either under the mattress or the "sofa" cushion.
briboy 04-03-2016 11:56 AM
Mine stays under the couch cushion - until I cook pizza - then I use it as a pizza peel
Seemore2006 04-03-2016 11:57 AM
And when it 'warps' from not using it just toss it unless you can find a way to 'recycle'.
graysailor 04-03-2016 11:59 AM
Never use it. Under the bed.
Murphalex 04-03-2016 12:03 PM
I hang ours on a command hook next to the stove once we get where we are going.
dkottum 04-03-2016 12:04 PM
We leave ours at home . . . somewhere?
However, I remember seeing a nifty large arc cut into the side of one by someone on the forum, so that sink cover could be used a cutting board/meal prep area and still have the faucet/sink function at the same time. I like that idea.
dsantopi 04-03-2016 12:31 PM
I put under the mattress of the bed. Fits nicely without being compromised :)
greghoro 04-03-2016 12:45 PM
Attachment 259903
Here is what I have done
Greg
