-   Tires (http://www.airforums.com/forums/f438/)
-   -   What is the absolute best tire? (http://www.airforums.com/forums/f438/what-is-the-absolute-best-tire-145696.html)
Kittyfeet 01-16-2016 07:31 AM
Money no object. What is the absolute best tire I can buy for 2016 23FB?
overlander63 01-16-2016 08:16 AM
Humvee airless tire test | Sciencedump
Top 01-16-2016 08:17 AM
Absolute best tire-
Are you asking for the OE 14" rim or are you you looking for any option including changing rim sizes to 15"?
field & stream 01-16-2016 08:23 AM
If "money is no object", I highly recommend that you start by upgrading to 15" wheels, as many of us 23' owners have done. Will only add about $500 to the cost.
Kittyfeet 01-16-2016 08:37 AM
Thanks for that recommendation. What tires?
Top 01-16-2016 08:46 AM
If you move up to 15" rims I would go with an LT215/75R15 Load range C or D.
This will raise your trailer 1/2"
GoodYear Wrangler H/T
Nexen Rodian HT
Yokohama Geolander A/T-S
You could even go to the LT235/75R15 LRC or P235/75R15XL. They will raise your trailer 1".
field & stream 01-16-2016 08:48 AM
We did the upgrade a few years ago and went with Michelin LTX M/S2 and are very satisfied. Check out this link:
Michelin Defender LTX M/S 235/75-15 109T XL
Popular wheels have been the Sendel T02 or T03. Airstream offers this wheel as an option.
Rgentum 01-16-2016 09:01 AM
The "absolutely best" tire is Michelin XPS Ribs, although they are only available in size 16 inch. They are also pricey, approx. $250, although I've read many reviews of their being almost bullet-proof & good on a truck or trailer for over 100K miles.
XPS Rib tires | Michelin US
dkottum 01-16-2016 09:45 AM
You will want reliability from sudden failure, soft ride, and excellent traction for braking. Most have switched to 15" wheels and Michelin LTX MS/2. Air pressure relates to all three desired qualities, and that preference is all over the place. We use a manufacturer's load chart for our tires to determine air pressure, with some extra pressure assuming not all tires are carrying equal loads on each particular trip.
Top 01-16-2016 11:06 AM
Very good tire, and the best for many Airstreams, but not for a 23'.
dkottum 01-16-2016 11:23 AM
The XPS Rib does not apply to the op's question, but there have been concerns about the stiffer sidewall and ride quality for Airstreams. We discussed it before:
http://www.airforums.com/forums/f438...s2-137278.html
idroba 01-16-2016 11:54 AM
Even if you toss out price as a qualifier in selection, there is no "best" tire that anyone can say for sure. It depends on your usage pattern (how often used) , area driven in (road conditions), heat, speeds driven, and so many other factors that the it is impossible to say. And no one has ever done any side by side comparison tests, if such tests could even be developed.
So, all you will get are opinions. Nothing more.
graysailor 01-16-2016 12:20 PM
Having been in the trucking business for close to 40 years I found Michelin and Bridgestone to be the best. I currently have Michelin on my TT and TV. No complaints. LT (light truck) tires would be the best choice.
Kittyfeet 01-16-2016 12:46 PM
Thank you everyone
