-   -   Restoring window support rods (http://www.airforums.com/forums/f164/restoring-window-support-rods-145578.html)
TxDave 01-12-2016 03:16 PM
Before removing the windows on my 1971 Sovereign to refurbish them I had to remove the support rods. I found the easiest way to remove the clips that hold the rods in place was to use a cut-off wheel in my Dremel. I just cut off part of the clip and used a hammer and screw driver to pop the clip off. Took about 20 minutes to remove all 8 windows.
Anyway...the support rods looked pretty bad after 45 years. I cleaned them up with a 1" belt sander from Harbor Freight using a cloth belt. As you can see from the before and after photo, this technique worked well.
I think paying attention to the small details like this is important IMHO.
cwf 01-12-2016 03:32 PM
Spray some Nyalic on it to keep it sparkly!
TxDave 01-12-2016 05:20 PM
Thanks, cwf. First I ever heard about the stuff (Nyalic). Did a google search...looks like something that would definitely be beneficial.
cwf 01-12-2016 09:55 PM
Dave,
I have a can I used to repair bad spots on our AS. Have some left if you want to test out. Of course, having the "system" they offer will give best results.
The areas I have treated have been great for over a year. No need to wax, polish, just great product!
rucos 01-13-2016 03:06 PM
I'm curious how much luck you have reinstalling the clips. Ive had several that just don't stay on long term. I get them on and all seems good then after using awhile they seem to pop off!
TxDave 01-13-2016 11:15 PM
I'll let you know how that works out, rucos.
curtisjinkin 01-18-2016 02:29 PM
Thanks for the post, where do you get new clips?
cwf 01-18-2016 09:44 PM
If using "E" clips, and they fall off, usually you are using an incorrect one.
Better yet, try a "retaining clip".... McMaster-Carr
Here is a link.. Look around.. May be available at auto supply!
curtisjinkin 01-19-2016 09:03 AM
Thanks for the link! Very helpful
