-   -   Septic Smell be gone (http://www.airforums.com/forums/f444/septic-smell-be-gone-144353.html)
jbsamba 12-04-2015 03:04 PM
Hello all- I'm pretty new here and wondering if anyone has an ideas on how to reduce or even get rid of the nasty smell that is coming from the small roof vent on the back of my 72 Safari.
I don't want to put any chemicals in my tanks because I dump them in a septic system on my land and I'm thinking I should try a charcoal filter like you would use on a bathroom septic vent (cost $50 or so)... but doesn't seem like that's the norm for airsteam trailers and I don't really see much for discussios on this.
Anyone found any solutions that work good?
Melody Ranch 12-04-2015 03:45 PM
Empty your septic tank daily. Clean it after you dump the tank....clean it well. Extent the vent pipe up several feet to carry the odors away from the trailer. Your talking about a toilet vent which is doing what it is supposed to do. It is what it is.
dznf0g 12-04-2015 03:51 PM
Use ridex for rvs (liquid) safe and healthy for your septic. There are other enzyme rv products as well, but I trust ridex brand as I used the home septic version for years and never had to have a pump out, let alone a problem.
jbsamba 12-04-2015 08:01 PM
Thanks for the feedback - I also saw something about the Camco cyclone vents might try one of those and the Rid X RV product
TinShack 12-04-2015 11:15 PM
I've been using the Pure Power stuff for years and it works great. Enzyme-based like Rid-X so septic safe and instantly makes your holding tanks smell Hawaii fresh. http://www.campingworld.com/shopping...r-16-oz-/69997
emalt 12-05-2015 02:01 PM
Check the drain valves to the sewer
My vents don't smell as long as the valves from the black and grey water tanks are closed. If they're open they're venting the septic or sewer system and it can get bad!. Double check the valves and only open them to drain the tanks
Wolf Alaska 12-05-2015 03:10 PM
Very good advice. I don't connect the dump hose to the sewer port unless actually draining the tank(s).
Using Dometic biotic tank treat & yields good odor control.
Let's Roll !
Wolf
batman 12-05-2015 03:11 PM
Exactly what emalt said x2.
You do not want to leave the dump valve open. That will create a problem with solid waist removal. It is not like the toilet in your house.
If the dump valve is open, the septic system will vent through the black tank and vent pipe on top of the trailer. Not good.
Dump the black tank when it gets 3/4 full, close the valve.
Follow with the gray water to flush the hose. Then close the gray water valve.
With the valves closed you should not get any odor from your septic tank or much from the black tank.
-Dennis
