-   Forum Admin, News and Member Account Info (http://www.airforums.com/forums/f138/)
-   -   Univolt why so heavy ? (http://www.airforums.com/forums/f138/univolt-why-so-heavy-142627.html)
shineybullet 10-18-2015 06:29 PM
I just removed the old univolt in my 1972 overlander and when I went to lift it out it really made me grunt, it must weigh over 60 lbs , I was wondering what's inside one of these old Bruts that make them so heavy ? I'm really curious 🇨🇱
0557 10-18-2015 06:32 PM
Because of the transformer that's in it for conversion
idroba 10-18-2015 07:31 PM
Prior to switching power supplies about the only way to convert voltage was with a transformer. In this case a big heavy one.
Electronics changed all of that, but transformer systems are still simple, very reliable and easy to understand. But the old Univolt is simply obsolete as a converter/charger system.
AWCHIEF 10-18-2015 08:19 PM
Good old solid American made steel and iron. Almost bullet proof and make great boat anchors.
DryFly 10-18-2015 09:34 PM
The reason it's so heavy is because it's got A LOT of copper for the windings. Take it apart and you'll see. Most of it can be recycled.
nrgtrakr 10-18-2015 10:22 PM
... wondering outloud why I didn't remove ours when I had the bathroom partially disassembled to replace the shower valve and plumbing ...
barts 10-18-2015 10:24 PM
The size of a transformer is inversely related to the frequency for which it's designed... so a switching mode power supply that runs at 20+khz will have a much smaller transformer than a 60hz model.
In the end, the ferroresonant Univolts are prob. more reliable than the
switching supplies that have replaced them - but the new units are much cheaper, more efficient and quieter. The new systems also provide for temperature adjusted charging voltages, and the three-stage systems won't cook your batteries, either.
- Bart
cwf 10-18-2015 10:40 PM
They are far lighter when you let out the "magic smoke"!
shineybullet 10-18-2015 11:28 PM
- Bart
It looks like mine must have quit working years ago,some pasr owner cut off its power cord to the Uni volt and wired a small battery charger in its place I'm putting in a 45 amp smart converter in its place with 2 huge 12 volt yellow top batteries :brows:
alantbird 10-19-2015 12:01 PM
1st one I replaced was in my 77 ambassador (in1999) and it was suddenly sooo quiet!
Royce 10-19-2015 01:13 PM
I gave mine to a local HAM radio operator. He changed it to an oil filled unit and is happy to give it a new home. I was happy to get the 75 or so lbs out and a new quiet converter in.
StarckMad 10-19-2015 04:11 PM
NRGTRKR: thanks for the confirming word. I still have our bathroom and closet apart for plumbing replacement. Might as well jump into that too!
nrgtrakr 10-19-2015 05:32 PM
Hahahaa!!!
Anytime ...
I wonder if it will fit through the battery box door if the battery compartment liner is removed?
I like our AS, but wonder about space utilization at times.
Jammer 10-19-2015 05:51 PM
I believe that the early univolts were ferroresonant, which added to their weight.
Ferroresonant transformers provide a measure of passive voltage regulation, and were a reasonably common design choice before high power MOS devices were available.
