-   -   2010 Flying Cloud Step Light (http://www.airforums.com/forums/f44/2010-flying-cloud-step-light-142277.html)
wscampo 10-11-2015 09:28 AM
My exterior step light has burned out and I have not found a manual or instructions to replace it or the bulb.
Can someone share information with those details?
Thank you-
wscampo 10-12-2015 06:07 AM
Attachment 250226
wscampo 10-12-2015 06:08 AM
This is the light. The trailer is a 2010 Flying Cloud.
lsbrodsky 10-12-2015 06:17 AM
I helped a person with a similar light and it was simply the ground wire had become corroded, not making contact.
Larry
Howard L. 10-12-2015 12:58 PM
I have a 2012. That looks the same. Mine is LED (8 lights) and you can not replace the bulbs. Must replace the entire light fixture. Order from AS customer service.
If you look at one side of the silver rim/cover you will see a slot for a screwdriver to pry the silver ring off. Once off two screws hold the plastic light fixture to the side. Just rewire and replace with the new one from AS.
The silver ring is tight and you will probably have to destroy it to remove--no problem you no longer need it. The new light's ring will snap on easily.
wscampo 10-12-2015 04:03 PM
Thank you
