-   -   454 to Cummins (http://www.airforums.com/forums/f159/454-to-cummins-141299.html)
choctawmel 09-18-2015 09:30 PM
454 to Cummins
Ok, I've been looking for days for the thread of someone converting a 345 home from a 454 gas to a Cummins diesel. Where the heck is it????
Isuzusweet 09-18-2015 09:36 PM
I do know of a 310 that was converted but I don't know if a write up on its conversion was placed on the forum. I wouldn't limit your search to just 345 but search Classic Cummins conversion.
http://www.airforums.com/forums/f311...-mh-26956.html
http://www.airforums.com/forums/f311...ns-129817.html
Cheers
Tony
choctawmel 09-24-2015 04:11 PM
So, in the line of: How you get that thing out of there?
Has anyone had the fun of removing the leveler pump and preserver from it's spot above the transmission? I need to get that think out to work on it.
Looks like the tranny must come out:<(
Isuzusweet 09-24-2015 06:53 PM
Leveler pump and preserver?????????? Air you talking about the air compressor?
bkahler 09-25-2015 07:04 AM
Tony, I think Mel meant the leveler pump and reservoir. Sometimes these spell checkers can wreck havoc with mis-spells!
When I dismantled the 345 I think I removed the engine and transmission before I got around to removing that pump and reservoir. That would really suck if you have to pull the transmission just to work on the pump. Hopefully someone will chime in with a way to get it out of there without pulling the transmission.
choctawmel 09-25-2015 07:46 AM
How true on the spellcheck, Brad, and I can't speell spell.
In the Silver Bullet, I'll call it the hydraulic pump/tank, sits about an inch above the top of the transmission. When I get it out of there, think it'll find a new home to go back to.
bkahler 09-25-2015 08:07 AM
I'm guessing Airstream installed the pump/tank on the chassis prior to laying down the floor grid work. Not the best planning on their part if that's the case.
On my old 310 the pump/tank was located in front of the radiator sitting on the chassis front extensions just behind the grille.
I can post some pictures if you would like.
choctawmel 09-25-2015 06:59 PM
I got it out today. Had to drop the tranny to get to it. Damn heavy! All I could do to get in on the floor w/o dropping it on my head! Think it will go back into the front wheel well after I get the motor rebuilt.
Isuzusweet 09-26-2015 07:10 AM
I'm guessing that's one more reason NOT to go with the stock HWH system and go with the Quadra Bigfoot, with each pump having its own preserver.:lol:
Cheers
Tony
choctawmel 09-28-2015 04:57 PM
Yep, had to drop the transmission to get it out of there. Let me tell that is one heavy piece of iron!
May see if it'll fix in the back of the drivers wheel well
Oh well, I needed to pull the tranny out and wash it off.... NOT!
bkahler 09-28-2015 06:36 PM
Mel, while you have the tranny out go ahead and pull the engine and drop a cummins back in it's place... :D
Punch 09-28-2015 06:59 PM
I remember there was a thread about a conversion to a Duramax about 2 or 3 years ago. Somewhere in the southeast. It all seemed to be going well with a lot of nice pictures, but then seemed to disappear. The DM seemed a very tight fit.
The problem to me about a Cummins, excellent engine though it is, is noise level. Whenever I say that, there's an indignant roar of "Oh, the old ones were noisy, but the new ones are quiet." The trouble is that for the last 20 years or so Cummins enthusiasts have been telling me that, but "the new ones" always sound just as noisy to me. I can only think that when you've driven a Cummins around for a while, everything gets really quiet..... birds stop singing, the TV sound has to be turned right up, and everyone seems to be talking to you in very low tones, even though they look like they are shouting.
carl2591 09-28-2015 07:18 PM
I was pulled up beside a "newer" cummings and it sounds, to me, like the older ones as well.
Now the new ford 6.7L diesel.. you would have to look at the logo on side of truck to know for sure it as diesel and not a gasser.. what is the world coming too...
my '03 7.3L is quieter since doing the fuel lines and some other mods.. even the wife noticed when we were driving around and I had not said a word.
tjdonahoe 09-28-2015 07:29 PM
The newer cummins are quiet,the conversion cost would be prohibitive in my view.....
