-   -   LP tanks (http://www.airforums.com/forums/f156/lp-tanks-141.html)
thenewkid64 03-19-2002 10:00 PM
LP tanks
Time to start gathering infomation for my next project!
I don't know about the rest of you but on my MH the LP Gauge is only correct for 1 day. The day it gets filled. Whenever I push the LP level switch on the Monitor panel it shows full.
Can the sending unit be replaced, where do I get this done. I do not want to run out of propane when I am out on a trip or at a limited electric rally.
ALANSD 03-20-2002 06:31 AM
you mean the gauge on thre panel inside?
Is there also the round gauge at the tank itself?
thenewkid64 03-20-2002 06:42 AM
The gauge I am referencing is the one on the Argosy control panel inside. There is a little round dial gauge on the tank as well but the pointer is broken off.
So I am assuming I need to have the tank based one replaced so I can get a proper level on one or both gauges.
ALANSD 03-20-2002 08:41 AM
I would bet the tank mounted gauge would be a much less costly replacement.
Also my experience has been ( and in cold weather)
that the gas usage is much slower than I would have expected.
I filled my tank to the allowable limit in December, and did three trips all using the furnace and stove,and still have almost 1/2 tank left. The former Ohio based owners said the tank would last them a year or more.
thenewkid64 03-20-2002 09:21 AM
I guess I am a bit paranoid coming from a travel trailer that automatically switched tanks, living in WI and traveling year round.
I have run out before and don't want to again!:p
