-   -   Septic system hookup (http://www.airforums.com/forums/f444/septic-system-hookup-13898.html)
rfield54 09-22-2004 09:06 PM
I'm going to connect my Excella to a septic system in a semi-permanent setting. I figure I'll come out of the drain valve with a 90 degree bayonet adapter and convert from 3" to 4" with a flexible rubber converter (with hose clamps), and then connect to the 4" sewer pipe (which will run 12' or so under the trailer). Any suggestions out there? How about a line on a good parts source? Thanks, Roy
Silvertwinkie 09-22-2004 11:37 PM
A home improvement store maybe.
Tarheel 10-02-2004 09:35 PM
most mobile homes only run a 3" waste line. You can find all the fittings you need a the local home supply. Use 1/2 bubble on your level to get a good drain flow on your lines.
Gambit242 09-04-2006 08:48 PM
How did the installation go? I'm thinking of doing the same thing and would love some "notes from the install".. :)
