-   -   1981 MoHo Diesel Converter/Battery Charger (http://www.airforums.com/forums/f156/1981-moho-diesel-converter-battery-charger-138108.html)
ranchmink 07-13-2015 03:38 PM
I am not getting any 12 volt power out of my Triad Utrad converter battery charger. I tested all the leads coming out. It creates heat and makes a slight noise which seems normal. I notices a wet area not water inside the unit with funny drill residues look like items. I have to assume its toast. I just got this and bought it knowing the unit did not work. What I would like input on is what is a good replacement for the TU-570-6 converter battery charger. I saw a WFCO converter Charger at Camping World and not sure if this would work or not model#58326. Would like some help on this which direction go go
Kota 07-13-2015 05:54 PM
Talk to these guys. Cheap and easy solution with superior performance.
http://www.bestconverter.com/
ranchmink 07-13-2015 06:24 PM
I sent them an inquiry will let you know their response. Thank you
ranchmink 07-15-2015 09:10 AM
I just ordered the converter from Best. I will update forum upon receipt on how the install is going after receipt. They answered my questions and where very responsive.
