-   -   window replacement (http://www.airforums.com/forums/f164/window-replacement-137237.html)
Greg1410 06-25-2015 02:34 PM
window replacement
I have a missing front window for a 1972 31 foot sovereign. I have the frame for the window. Can I take the frame into an autoglass shop and ask them to make a window and piece the frame back together? Or is just buying an entire new window/frame the better option.
montanablue 06-25-2015 03:22 PM
Cheaper to go to glass shop and get tempered glass with pencil edge
Belegedhel 06-25-2015 03:32 PM
Welcome to the forums!
Yes, the front window can be reglassed, relatively easily. Surely much cheaper than buying a whole new window, frame and all.
Angela Lowe 07-23-2015 07:58 AM
I am looking for a wing window for my 1973 Argosy.Its the road side one.
Belegedhel 07-23-2015 08:03 AM
These can be bought new from outofdoorsmart.com or Inlandrv.com. You might also find them used from silvertrailersupply.com. You can also look on the classified ads. When you see how much a new unit costs, you might want to be sitting down.
good luck!
Inland RV Center, In 07-23-2015 08:28 AM
Argosy trailers used "wrap windows".
Wing windows are about 14 inches wide. Wrap windows are about 40 inches wide.
You will also need a tube of Vulkem sealer and 100 "Olympic rivets", unless your going to use "buck rivets".
