-   -   PD 9245 Wiring (http://www.airforums.com/forums/f37/pd-9245-wiring-137170.html)
CBWELL 06-24-2015 09:12 AM
PD 9245 Wiring
I am replacing the converter in my 1994 Excella with a PD 9245. There was a 12-14 gauge wire connected to the old converter, and I have no idea what it was for. Anybody have an idea, and where can it be connected with the new conveerter. Thank you, Chris
richw46 06-24-2015 10:20 AM
Originally Posted by CBWELL (Post 1641584)
I am replacing the converter in my 1994 Excella with a PD 9245. There was a 12-14 gauge wire connected to the old converter, and I have no idea what it was for. Anybody have an idea, and where can it be connected with the new converter. Thank you, Chris
Where was the wire connected on the old converter? Chassis ground, perchance? There's supposed to be a grounding lug on the AC side of the converter. Can you use a multimeter on the wire to see if it has voltage or to see if it goes to ground?
drboyd 06-24-2015 11:15 AM
Where was it connected to the old converter?
CBWELL 06-24-2015 11:15 AM
Thanks for the reply. Stupid me, should have read on the old converter!!! Wire was for the indicator light. No longer required. Thank you. Converter in and working 100%.
