-   -   Dometic refrigerator wiring (http://www.airforums.com/forums/f37/dometic-refrigerator-wiring-13668.html)
walter1 09-07-2004 11:25 AM
I have a 2003 Dometic RV refrigerator model RM2551 for my 64 Safari. It requires constant 12vDC to operate the circuit board. The installation manual says to use distinct 12vDC + and - wires for this. I have an existing 12vDC + line run to the refrigerator area. My 12vDC system uses frame/shell for 12vDC to ground. Do I need to install new 12vDC +/- lines or can I use the existing wire and run the line to frame ground?
thenewkid64 09-07-2004 12:59 PM
Frame ground has worked for me. Just be sure to hit a rib or other thick metal. All of the 12 VDC is running on a common frame ground anyhow.
walter1 09-07-2004 02:21 PM
Thats what I figured, Just wanted to check. I'll make a point of making a good solid ground point. Thanks
