-   -   Potable Water Tank (http://www.airforums.com/forums/f443/potable-water-tank-13578.html)
Lee Pace 09-01-2004 07:59 AM
Potable Water Tank
I am debating whether or not to move my inside tank. It sweats when the furnace is on. Does anyone else have this problem? Were all the 69 Overlanders made this way?
Don Pace
69 Overlander
WBCCI 7287
till 09-01-2004 04:34 PM
Don,
It would not suprise me if yes all 1969 model Airstreams have the same paroblem.
I'm replacing my floor, so I plan on moving my water tank to under the kitchen floor and upping to 45 gallons.
markdoane 09-01-2004 04:39 PM
Originally Posted by till
Don,
Tedd,
Can you give us some details-what kind of tank? Insulation? Frame modifications?
till 09-01-2004 05:04 PM
OK,
I am planning on using the tank from Inlan RV. I will have to move a frame cross memeber or two, but I will have a bare frame anyway to get at it to weld. I an assuming that I will have to insulate around, I am using my neighbors 78 as a referance for this side of the "upgrades".
uwe 09-01-2004 07:44 PM
OK,
Please be aware that the frame rails on earlier trailer might be narrower ( closer together) than on the 70-on.
I am unsure of the 1969 model, but my 1963 is several inches narrower than my 1971. The tank pictured would fit my 1971, but perhaps not an earlier model.
