-   -   Here's a weird one, but it is what it is (http://www.airforums.com/forums/f447/heres-a-weird-one-but-it-is-what-it-is-133439.html)
dznf0g 04-08-2015 02:06 PM
At the end of last season I installed a brighter LED pad light with an 1156 base in the shower overhead fixture. I just noticed that whenever I turn on the shower light, I lose all over the air digital signals on the TV.
Doesn't lose signals with the old LED cluster bulb nor an incandescent bulb. Must be some noise generated on the 12v circuit?????
rmkrum 04-08-2015 02:11 PM
Yep. Probably generates some noise and messes with the TV amplifier. Try a different LED?
Belegedhel 04-08-2015 02:12 PM
My guess is that you have a loose connection or noisy switch that is spewing out EMR. In my house, if I operate the ice dispenser on my fridge, it knocks out the digital TV signal as well.
cwf 04-08-2015 02:15 PM
Our MW also took out all 802 signal in our home till I reoriented the antennas
dznf0g 04-08-2015 02:17 PM
As I said in the 1st post.....works fine with an LED cluster bulb and with an 1156 incandescent. Just knocks out the signal with the "pad" LED with an 1156 base pigtail. That eliminates the circuit or switch from having an issue. It is consistently repeatable.
mojo 04-08-2015 02:25 PM
Your Faraday Cage is possessed!
dznf0g 04-08-2015 02:27 PM
True dat!
rmkrum 04-08-2015 03:31 PM
Sometimes a largish ferrite core with the supply and ground leads wrapped through it a few times can help. Available at Radio Shack, assuming there is one still open in your area.
dznf0g 04-08-2015 03:38 PM
Not a biggie, I'll just shower with the more dim 1156 LED bulb....nothing there I want to see anyway!
rmkrum 04-08-2015 05:46 PM
TMI.....😁
cwf 04-08-2015 05:57 PM
Just leave the lights off!!! Sorry!
richw46 04-09-2015 08:13 AM
I found an interesting article on this. They point to cheaper LED bulbs as one culprit. The other is TV wire shielding. Two possible fixes:
1. Buy a different brand of LED bulb (just 1) and try that in the socket causing the problem
2. Try quad-shielded coax on the TV cable.
The Digital RVer: Does LED lighting put your RV TV on the fritz?
SteveH 04-09-2015 09:19 AM
It's the LED's. I have some in my Casita that will do the same thing. The later and supposedly better quality ones I bought do not effect the TV.
Air83 04-09-2015 04:30 PM
I bought my bulbs from M4 Products . I have not had any problems with them.
