-   -   Location of Inverter Outlet(s) in recent Sport 16'? (http://www.airforums.com/forums/f295/location-of-inverter-outlet-s-in-recent-sport-16-a-130737.html)
Lhunter59 02-02-2015 10:02 AM
Hi, does anyone have a recent Sport 16 with the inverter option? Just wondering where they located the inverter outlet(s). Have installed a Morningstar Sure Sine but still need to install the outlet(s).
Larry
Lhunter59 04-02-2015 12:45 PM
No one has a recent Sport 16 with a OEM invertor?
Lhunter59 04-16-2015 11:00 AM
No one has a recent 16' with the factory inverter option?
ckottum 04-16-2015 12:07 PM
With one battery to supply it as well as other 12vdc equipment, maybe there is no inverter option for the 16 Sport. On larger models they are located below the dinette, near the Blu Ray player, near the tv (front and back). None in bath or galley. Primarily for television and computer charging, rather than coffee makers and hair dryers because of the limited power of the coach batteries.
cheryl
Lhunter59 04-21-2015 12:05 PM
Thanks that helps.
Lhunter59 06-11-2015 04:39 AM
In the end I installed a power bar at the front top of the street side dinette base and drilled on small hole in the top right of the base to get the wire to the inverter which is right behind the power bar.
