-   Our Community (http://www.airforums.com/forums/f48/)
-   -   Do you drink the water at RV parks? (http://www.airforums.com/forums/f48/do-you-drink-the-water-at-rv-parks-127776.html)
cantdrv55 11-11-2014 03:09 AM
Total newbie question because I am a total newbie. I've read that I should use a white hose for fresh water but does that mean the park's water is drinkable? Even when I stay in hotels I drink bottled water. If you don't drink it, do you cook with it or is it just showers, washing dishes and flushing the john?
dwightdi 11-11-2014 04:49 AM
We carry a 2 1/2 gallon water from home. Use it to drink and cook when quality is questionable. Most Midwest state campgrounds have acceptable water. Bottle water is getting cheaper at most big box stores.
wahoonc 11-11-2014 05:50 AM
We use the campground water supply for showering and washing up. Drinking and cooking water comes from home, or if on the road for any extended length of time we may buy gallons of drinking water. In addition all campground water gets filtered by an external filter first. We had one campground where the iron levels were so high that we threw the filter out after a weeks stay.
Aaron:cool:
dznf0g 11-11-2014 06:13 AM
Yes
paiceman 11-11-2014 06:39 AM
Use it for everything, but also have an inline water filter. After a seven week trip this fall I took the filter out when winterizing and was amazed how dirty and red the filter was. Spent a lot of time in Moab - Red Dirt. We have never had an issue when using the inline filter.
Safe Travels
timhortons 11-11-2014 06:44 AM
You do realize bottled water is usually just water from a municipal supply with the added bonus of soft-plastic taste ?
lewster 11-11-2014 06:55 AM
Reverse osmosis from home supply or distilled water when on the road for drinking. Most bottled water is a scam and tastes horrible when compared to the two options above.
Lew Farber
RVIA/RVDA Nationally Certified Master Tech
Master Tech Energy Systems, Inc.
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
AnnArborBob 11-11-2014 06:59 AM
We almost always use CG water for everything and have never had a problem (knock on wood!) Having said that, we do carry some jugs of water and are prepared to use them for cooking/drinking if the CG water has an off taste. I figure as long as I don't see the bodies of too many dead fellow campers outside their units how bad can the water be? Also, realistically we are never in one place long enough for a "silent killer" type of contamination to build up in our systems. However, if you are among the folk who drink bottled water at home and in major cities because they are afraid of contamination even in those supplies, then by all means, knock yourself out and drink the bottled water! :lol:
Lily&Me 11-11-2014 07:12 AM
All campground water, all the time, but for the occasional places where we have been forewarned not to.....like Moraine View State Park and Edisto Beach, where the fresh water is safe but tastes nasty, for different reasons.
The blue filters available at WalMart do a nice job of equalizing the taste from one area to the next.
Maggie
AStreamJake 11-11-2014 07:27 AM
We drink the water at almost all campgrounds we visit, unless (such as in Arizona), the local supply is not to our taste.
60 minutes did a segment on bottled water years back. Most municipal water supplies were far less contaminated than brand-name bottled waters. Almost all bottled waters come directly from the tap at the factory and have far better chances of contamination because of the bottling process itself and the storage periods involved.
If you want to spend a lot of unnecessary money, use bottled water only (although, truthfully, you won't be any safer.) If you have concerns but don't want to use bottled water, get a simple filter from Walmart such as someone suggested above. Or if, like me, you believe that the U.S.'s water supply is the safest in the world, drink bottled water only if you have taste objections to the local municipality's supply.
AnnArborBob 11-11-2014 07:50 AM
I would like to remind folks who are commenting about the safety of US municipal water that a lot of campgrounds use well-water and do not get their water from a municipal water supply. We have well-water at home and are thus used to water that does not come "from the grid" and feel it is perfectly safe. :)
nvestysly 11-11-2014 07:54 AM
We use campground water for almost everything - cooking, shower, brushing teeth, etc. We're not overly concerned about safety of the water supply when we travel. We take precautions to keep the ends of our white hoses out of the dirt and we don't put the white hoses near the sewer hose - a common sense approach.
We do use bottle water - if you can call it that - for drinking. We refill jugs at the grocery store for $0.25 - $0.35 per gallon. Yes, it cost money but if it's only for drinking we only need to refill the jugs every few days.
The water from those dispensing machines has a more consistent taste in my opinion versus the taste of water from town to town. When the municipal water has a odd flavor it causes me to not drink the water and then I find myself becoming dehydrated. The water from dispensers has the added advantage of not creating calcium or iron build-up in the water kettle for our morning hot tea and oatmeal.
I've considered adding a water softener to our list of equipment in order to reduce iron deposits and calcium buildup in the shower and water heater.
AWCHIEF 11-11-2014 08:18 AM
Yes I do drink the campground water. I use an inline filter to strain out the big chunks and a filter that is built in to the galley faucet.
polarlyse 11-11-2014 08:18 AM
Well water for consumption is periodically tested so should always be safe to drink. Taste, that's another issue and if you don't like it, don't drink it. I do use bottled water usually for making ice and drinking but I do try the campground water first. I've been thinking lately about a small RV softener and may look into that one of these days.
