-   Clearcoat, Exterior Paint & Trim (http://www.airforums.com/forums/f474/)
-   -   Clearcoat (http://www.airforums.com/forums/f474/clearcoat-126255.html)
Hotlead 10-05-2014 10:09 PM
Clearcoat
I am going to get Aircraft Remover in the morning and use it to do the deed. I am replacing all exterior lights afterwards , do I need to protect the windows if I brush it on and low power wash it off ?
Hotlead 10-06-2014 12:49 PM
I got the citristrip instead and got poor results after 3 hours. Can the stronger Aircraft Remover be wash off or do you have to scrub it too ?
Attachment 223793
NJtoNC 10-06-2014 01:35 PM
It can be washed off. It's very toxic. You need full body covered and multiple pairs of gloves.
Tltulsa 10-06-2014 01:46 PM
Windows are glass, right? Probably fine. Just don't get on plastics (ie: acrylic rock guards covering windows). I learned this the hard way.
airdreamers 10-06-2014 04:18 PM
I used Klean Strip from Lowes, works great. $18 + quart. Worked great, put it wait till it just starts to dry, scrape with a plastic scraper. Reapply in areas where needed. Remove residue with soft cloth damp with paint thinner. I am only stripping and polishing from the roof to the upper rub rail, since the lower area is in excellent condition. Power washing is not an option in my case. I therefore used masking tape and a protective cover from the upper rub rail,down. I am very happy with the results!
Hotlead 10-06-2014 04:18 PM
I put on about 7 coats of this Citristrip and the panel still has clear coat in places. I think I am going to get some mineral spirits tomorrow and call it quits. Will the mineral spirits get rid of all the gooey smears ?
Hotlead 10-06-2014 04:21 PM
How long to dry ?
Wash off ?
airdreamers 10-06-2014 04:24 PM
Don't call it quits, you are almost there just have a little more patience, you will succeed. Just don't expect fast results.
Hotlead 10-06-2014 04:24 PM
Attachment 223796
My untouched panel looks better than what I've been trying to strip !
Inland RV Center, In 10-06-2014 04:50 PM
Originally Posted by Hotlead (Post 1521210)
Attachment 223796
We have used Aircraft stripper for many decades.
Usually, but not always, is 100 percent of the old clearcoat removed.
Sometimes a second coat over a small area is needed.
Rarely, was any rubbing necessary.
eubank 10-06-2014 05:09 PM
Yep, I used aircraft stripper as well. It's mighty dandy stuff, great for removing clear coat and getting rid of ugly brown spots on the back of your hands, too. :)
Just to make sure, by the way, I purchased a relatively soft dish brush at the grocery store, one soft enough that it wouldn't scratch aluminum. Once the stripper had set for a while, I then used the brush to scrub the stuff around on the surface of the aluminum, making sure that no little spots of clear coat remained. Then rinsed.
Lynn
Hotlead 10-06-2014 05:09 PM
The Aircraft Remover ?
How do you apply it ?
How long do you leave it on ?
How do you remove it ?
Hotlead 10-06-2014 05:15 PM
This is what I am finding in town.
reinergirl 10-06-2014 05:24 PM
That will do it.... Do not get it on you, the stuff burns in seconds. Wear very good eye protection too!
