-   -   Steps "frame" by the door.. Help please! (http://www.airforums.com/forums/f164/steps-frame-by-the-door-help-please-126213.html)
a_magyar 10-04-2014 02:50 PM
Not exactly a door problem, but I wasn't sure where to put this question, so here it goes.
That frame what it holds the steps in my 1973 Argosy, the right side totally rusted, and cracked. I removed the steps, and wondering if is available to order that "frame"?
I don't know anyone around here who has a welding/machine shop, because I thought it is possible to cut it out a lower part (marked with red dots) like a triangle, and just weld it back a sheet of metal, and paint it over.
The steps can't slide in , and out freely anymore because of the rusted part.
http://www.airforums.com/attachments...937127c644.jpg
The left side in good condition:
http://www.airforums.com/attachments...156c5a3985.jpg
The right side again:
http://www.airforums.com/attachments...fbdd9e8b68.jpg
Top 10-04-2014 03:07 PM
Outrigger for step attachment LH 410524 [410524] - $24.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
terryV 10-04-2014 03:08 PM
If you can buy the "frame" it would probably be the best fix.
However, if you can't, you should be able to find a good local auto body shop to make a piece and weld it in.
BradS 10-04-2014 03:28 PM
Try either out of doors mart or Silver Trailer Supply. I think both will have that "outrigger"
batman 10-04-2014 03:41 PM
Keep the original. I had the same piece cut and welded for the step on my Safari, it came out great. It looks all original nothing after market. If you can't find a welding shop, terryv had a good Idea try a body shop, or even a metal fabricator near by. If you buy an after market step, i suspect you will have to get the old one cut out, and the new one welded in place by some one. Look up mobile welding, there may be some one in your area. My .02
a_magyar 10-04-2014 06:29 PM
Thank you guys! I just ordered one, and my buddy will help to weld it in :)
