-   Clearcoat, Exterior Paint & Trim (http://www.airforums.com/forums/f474/)
-   -   Bedliner spray on the top of the Argosy? (http://www.airforums.com/forums/f474/bedliner-spray-on-the-top-of-the-argosy-125357.html)
atti_mac 09-14-2014 07:11 PM
Anybody ever was thinking about to use a bed-liner spray on the top of the camper? I don't have a shinny airstream, I have an Argosy , so it wouldn't bother me, but I was wondering if somebody did it before? :)
TanCanMan 09-15-2014 09:25 AM
Greetings from Houston,
I am planning on doing the same thing to an old Spartan - to make sure it is sealed and durable. It currently doesn't have any paint on it and I was told that it would be necessary to etch the aluminum or the bedliner would eventually peel off. You should be OK since the Argosy has already been prepped for paint. I'm sure others will join in but I would think it is a good solution for you. Best of luck and look forward to hearing how it works out for you.
J. Morgan 09-15-2014 10:01 AM
If you sand it good with 80 grit paper it will stick.
If I were to bedline the roof, it would be with WHITE bedliner.
perryg114 09-15-2014 10:08 AM
Seems like it would be a bit heavy to me. If you need to repair or replace something it could get messy.
Perry
7GenTex 09-15-2014 10:11 AM
Rhino Liner
Believe Rhino Liner has come out with a product specifically for such..................
Arcticfox 09-15-2014 11:01 AM
They have - here is a link...
Rhino Linings Corporation | News - Coatings Company Press
atti_mac 09-15-2014 11:13 PM
Thank You for the link!
r carl 09-16-2014 05:47 AM
I seen Line-X spray Dupont vari-prime on a truck bed before they sprayed the bed liner.
Zil 09-16-2014 08:45 AM
Here is a VW complete Bed Liner.
ALANSD 09-16-2014 10:45 AM
Invisible...awesome
Tater 09-16-2014 12:23 PM
I would want to be absolutely that whatever is sprayed on must not be affected by UV. If it starts to deteriorate from UV it could be a challenge trying to remove the product.
J. Morgan 09-17-2014 08:04 PM
Here is some bed liner I sprayed on today,,,
I wouldn't use black on the roof though.
Attachment 222113Attachment 222114
