-   -   window replacement 1997 Excella 35' (http://www.airforums.com/forums/f164/window-replacement-1997-excella-35-a-124722.html)
king4day 08-31-2014 04:15 PM
I just bought a 1997 35' Excella 1000 and it has a broken window on the side second to the left of the entrance door. Is this window easily replaced by a glass installer or is this a special order Item? Where would I order it from if so?
Aviator 08-31-2014 05:37 PM
You can order it from any aairstream dealer and have it shipped to you. The windows are hinged at the top and simply rotate up until the "J" clip at the top disconnects from the aluminum frame around the window. Installation is the reverse. Oh, you do have to disconnect the arms on each side of the window. The last time I checked it is about $200 for one of those larger windows.
