-   1999 Safari (http://www.airforums.com/forums/f196/)
-   -   Need Window for 99 Safari (http://www.airforums.com/forums/f196/need-window-for-99-safari-124031.html)
Okiestreamer 08-16-2014 07:52 AM
We need to replace a broken window segment in our newly acquired '99 Safari. It broke after being cranked to close but stuck open. A few minutes later it closed itself but so hard that it shattered the glass. I'm sure we aren't the first to experience this so can anyone help with finding a replacement piece and how to install it? From what we have read this is a Creation window and they have been out of business for a while.
Thanks for your help.
timmaah 08-16-2014 08:58 AM
Our side window did the same thing a few months back. We could not find a source for a replacement.
We took off one of the other windows to be used as a template and dropped both off at a glass shop. They managed to make a replacement to match fairly closely to the original. Color and fit look good but the glass is a little wavey. Most likely only noticeable by me and no one else. Was under $50.
Okiestreamer 08-19-2014 02:33 PM
Removing a Creation Window segment.
timmaah, thanks for the info. You mention you took off one of the other windows so I have another question. See the attached pic and note. How did you get the other one out?
timmaah 08-19-2014 10:05 PM
Gently but with some force.. with the window tilted up like in the picture.. pull straight down. There is a little C hook that is the hinge.
Ladylongwing 08-03-2019 09:01 AM
I am also looking for a replacement rear street side window. Any sources for salvage?
