-   -   Used windows (http://www.airforums.com/forums/f164/used-windows-122962.html)
Harperbear 07-23-2014 07:42 PM
Used windows
I need a couple of used windows for a 69. I tried using the classified section but had problems with the search engine. If anyone has a source for used window i would appreciate the info.
Jim & Susan 07-23-2014 08:09 PM
They're hard to find. Which windows are you looking for? It may be easier to replace with Plexiglas or something similar.
Harperbear 07-23-2014 08:16 PM
I need a couple of the 40" ones and a wing window.
Kyle401 07-23-2014 08:57 PM
You could try Colaw's near Joplin Missouri. The wing window will probably be the toughest to get since they are unique to the '69 model year. I believe both are available new.
Jim & Susan 07-23-2014 09:08 PM
Colaws is a great source. I've bought several items from them. If you have the frames and they are in usable condition, you may be able to have a local glass shop replace the "flat" window glass. The wing window glass can be replaced with Lexan or plexi.
Harperbear 07-24-2014 06:35 AM
I'll call them today. Thanks for the tip. I am trying to avoid using lexan and the new glass ones seem to be out of stock.
