How is this possible, same manf, almost same frame, diff GVWR
case in point.
2003 Ford F-250 SD with 7.3L PS diesel pickup, extended cab, long bed, 158" wheel base. VIN tags show Gross at 8800.. but the axles weight, front 5200, back 6084 = 11284 LBS, is quite a bit higher than gross.. now look at this. 2003 Ford Excursion with 7.3L PS diesel SUV, 137 Wheel base, VIN gross 9200, front 4700, back 5250 = 9950 LBS, which is just slightly above gross on tag.. What gives.. On SD, vin shows transmission as 9, axle as C1, excursion trans is a B and axle C1. so why the big difference in gross and axle total weight.. too me it appears the SD is underrated on gross by 1000 lbs or better.. :huh: info is from this SD, http://www.autowarehousesalesnservic...spx?id=4545377 and this excursion, http://www.autowarehousesalesnservic...spx?id=4666199 |
First off, you're comparing a superduty pickup to an excursion - two different vehicles.
I have an '05 Excursion and a bit later 250 PU. The suspension is very different - especially on the front end. Different spring codes call for different ratings. Transmission cooling capabilities will effect gross. Best to stick with the Manufacturers rating - many expensive engineers have thrown many hours at the ratings - they would not downrate any vehicle without a solid reason. |
When they spec'd heavier axles for the pickup, they would have allowed more headroom for not knowing where the owner would place the load, more fore or more aft. The Excursion would be designed for carrying the weight more between the axles.
No reason for GVWR to be the sum of the axle ratings unless you can control weight distribution between axles. Also, as noted above, there are more considerations for GVWR than axle capacity. |
They may also have completely different axles. Ford uses a number of axles and sizes. There are a number of contributing factors. As 87MH pointed out, the engineers know what they're doing.
Are you expecting FGAWR + RGAWR to equal GVWR? It doesn't work that way.
another point on the engineers know what they are doing,, then explain the 6.0L engine .. sorta make that something you make you go HUMMMMMM... the axle code on VIN is same for both .. ??? |
What about the 6.0L engine? My 4 door Pontiac G8 GXP has a 6.2L v8 with 3.92 rear end, and produces 415hp & 409ft/lb of torque. They also put the 6.2L in the 2500HD's, but that doesn't make my Pontiac suited for towing. :)
no 6.2s in 2500s. Only 6.0l. 6.2 goes in high end SUVs and Max Tow 1500s.
I think he's talking about the Ford 6.0L diesel....which was problematic. |
