-   -   Air Cleaner Retrofit (http://www.airforums.com/forums/f159/air-cleaner-retrofit-121184.html)
Air Dog 06-13-2014 06:34 AM
9 Attachment(s)
Ive never been impressed by the factory installation of the air filter on my 360.
Attachment 214127
It is impossible to service properly without completely removing the canister which risks getting dirt into the induction tubing. You can loosen the mounting brackets and force it up on the rubber couplers to remove the cartridge but that risks dirt falling out of the pleated filter into the turbine inlet. I believe that was the cause of the impact damage on my turbo by the POs.
Attachment 214128
The air intake tube was about 6 feet long and sucked the dustiest air possible from this 2' x 2' x 2' mystery box in the rear corner. There is a louvered 10" x 10" inlet on the rear corner. The box is "isolated" from the rear by rubber blankets. There are huge gaps that allow air from the engine compartment and rear cowling into the box where this huge 8" vacuum cleaner hose happily ingesting anything that enters. One disadvantage of a rear engine is that it is in the dirtiest, dustiest position possible.
I experimented by relocating the existing canister.
Attachment 214129
Attachment 214130
I ran it that way on our spring trip for about 3000 miles and was happy with the results. It wasn't sealed off from the engine compartment so not truly a cold air inlet but no worst than the original. It did free up space in the engine compartment to relocate the coach batteries to the rack. That really worked out well!
Attachment 214131
After hours of research and searching I found an air cleaner that was perfect for the application. It's from a 2012 Freightliner M2. Its from Donaldson and uses the PowerCore axial flow filters. They boast 10x the efficiency over the pleated filters. Designed for 500 hp it should be overkill for the little 5.9L.
Attachment 214132
The new configuration uses the existing 4" to 5" 90 degree elbow and 5" aluminum tube with a 5" to 7" hump connector and the Freightliner filter.
Attachment 214133
I fabricated some baffling to seal off the air box and mounted the filter.
Attachment 214134
View looking in through the air inlet opening.
Attachment 214135
I'm very happy with the results. It's very easy to service through the side louvre. The filter design virtually eliminates the chance of getting dirt in the intake during service. The cartridges are $37 vs $70 for the stock cartridge. It has a safety filter to prevent FOD.
Air Dog 06-13-2014 06:43 AM
The airflow should much better than the original and the air source is 100% fresh air through the side vent. I'm expecting much less dust to enter the filter and colder air.
I also believe I got better airflow through the engine compartment for cooling by removing all of the obstructions of the stock system.
One other improvement was creating more clearance for servicing the oil filter. The stock installation squashed the rubber elbow off the turbo into the top of the filter. It created the possibility of getting dirt into the top of the oil filter during changes.
The original had 4 90 degree turns and about 7 feet of flex tubing.
I did have to enlarge the side inlet slightly to get the 13 inch diameter filter cartridge through it. The original louvre covers the hole but I'll fabricate a new one next week. I'll post an update.
Air Dog 08-10-2014 03:03 PM
4 Attachment(s)
Attachment 218813
Attachment 218814
Attachment 218815
Old inlet in enlarged hole...
Attachment 218816
Got er dun!
Last step was fabricating a new inlet louvre. I had to enlarge the opening about an inch to accommodate the air filter element. Changing filters is now a 10 minute job with easy access. The new axial flow filters make it nearly impossible to get dirt in the intake.
Colorado emissions test next week and then the fall trip.
