-   -   Breakers in 2014 International (http://www.airforums.com/forums/f37/breakers-in-2014-international-119400.html)
NatandGregg 05-04-2014 05:27 PM
This weekend we were over 100 degree weather:bb:, had A/C, vent fans, and micro going. We were hooked to 50 AMP service at RV park. 20 Amp breaker tripped twice, once with only air and vent fans on, the other when Micro, A/C were going. Does the breaker need changing out?:angel: Also, is it possible to upsize the standard A/C?
gmw photos 05-04-2014 05:30 PM
I wonder what the line voltage was at the park ? Did you have a good surge protector connected up ? One that would power down in case of low voltage.
EDIT: ps, I am not saying that "is" what it was, I'm just wondering if it might have been the problem or part of the problem.
idroba 05-04-2014 05:44 PM
I could be low voltage at the campground, or it could be a breaker or wire tightness issue which on a 2014 should be handled by Airstream under warrantee.
It may be hard to duplicate at the dealer of course.
Why are you running the vent fans (I assume the Fantastic Vents in the ceiling) while you are running the AC? That will only pull hot air in through every crack in the trailer and can easily overcome the AC cooling capacity.
Airrogant 05-04-2014 08:58 PM
It is unlikely that your circuit breaker is bad. If you do decide to replace it you'll want to make sure that you don't install a larger breaker in it's place.
While a larger breaker might eliminate tripping, it will also increase the probability of a nasty fire.
