-   -   Exterior Damage: Is It Worth It? (http://www.airforums.com/forums/f381/exterior-damage-is-it-worth-it-118702.html)
surfside1 04-19-2014 12:19 AM
Hi, all. I do not own an airstream yet, but my wife and I are looking. I have found this one, and I have only taken the following exterior pictures of it. There is obvious damage to the top of the unit, toward the front. I would imagine that there is rib, skin, and interior damage, as well as more that I don't see from the outside.
I figured this forum was the best resource, to find out from current owners, whether the you could recommend whether it is financially a bad decision to even try to repair this particular trailer, or if something this is far too involved to make it worth the trouble. You may tell me that it is not as bad as it looks, and the repair is manageable. I just don't enough about it.
If you tell me that it is worth finding out more about it, then I will approach the people whose property it is on, since there has been an orange sticker on it from law enforcement, notifying them that it will be towed soon, if it is not removed from that spot.
Thanks in advance for any input.
Attachment 209935Attachment 209936 Attachment 209934
Inland RV Center, In 04-19-2014 12:35 AM
It's already been patched, so a few more won't hurt, if done properly.
If you looking at that coach as a fixer upper and then travel with it, it appears from the photo's that the axles need replacing, amoung many other things.
A price of maybe $ 1000.00 is enough, but only if the inside is reasonably OK.
ROBERTSUNRUS 04-19-2014 12:49 AM
Welcome to the forum.
:) Hi, not an expert on fixing old trailers, but it would depend on what the trailer cost you and your ability to fix it your self. It also looks like it has a huge patch above the belt line and just behind the door. Wonder what that may be hiding?
vinstream 04-19-2014 03:08 AM
on that age trailer... Hell NO move on!
m.hony 04-19-2014 04:59 AM
The clear view window is broken. How long has it rained in the trailer? Unless it was free and I could repair it myself...
What is the orange sticker? Is the highway dept. coming to get it soon?
RM66caravel 04-19-2014 05:25 AM
Can be fixed so if it were cheap and could be towed and if I were in the market then maybe but the door is strapped shut and besides the obvious what's it look like smell like and is there an interior? Better than some that I have seen!
Cliff
scamp 04-19-2014 05:31 AM
The trailer looks like a older one and if you look at the trailers wheels ,large patch it tells you that the owner didn't really take care of it or didn't do proper repairs so if you buy it once you start working on it, the terrible work or maintenance on this trailer will cost you more then if they just left it alone, if you want to do it right it's going to cost a lot as your going to need some ribs,two full upper half panels running the length of the trailer ,a full roof panel,plus interior roof panel,upper side panels, plus window looks bent ,and that's just the start ,plus labour,everything is telling me stay away from it! Unless it's some kind of rare trailer ,famous trailer( I don't think so )it's gotta be very special to you as the cost is going to exceed finding another trailer the same but well cared for.
BradB 04-19-2014 06:15 AM
There is enough work in those 70's trailers without involving yourself in massive bodywork I think. Unless it were free, I would run!
Colin H 04-19-2014 06:55 AM
This is repairable, however it will take quite a bit of work. You don't have to replace the roof panels, only the area where the worst damage exists. The interior skin will have to be removed in this area as well, in order to access the damaged ribs. The ribs will not have to be replaced either, however they will need a lot of metalwork & reinforcement. I have repaired damage like this without replacing or patching the roof & the end result was un noticeable. The other side of the coin is that what other problems exist with this trailer? It likely suffers from every other issue that this era suffers from, so its going to be a lot of work, any way you look at it. It sounds like you could pick it up for a song, if not free. If that's the case, go for it, however keep things in perspective & approach the repairs very methodically & at a pace you can you can afford.
Good luck,
Colin
aceflys 04-19-2014 07:15 AM
I won't touch that with a ten foot tree(Oh that already happened). You will be in it 3 times the $$$ then that will ever be worth. In the long run it is much better to find a good AS to start with. Just in axles and the door lock you're already in $1500 the range. That window is not cheap. The step is hang down the missing door on the side. The water damage on the inside, frame rust, floor rot it go's on and on. I would move on! You can thank me later.LOL
Ace in PA
RM66caravel 04-19-2014 08:25 AM
There may be some useful parts in her and although she has been mistreated she may still be useful! Maybe as a major project for the rich and famous or as a donor for a less damaged project.
Cliff
ggoat!!! 04-19-2014 08:52 AM
You could make a LOT of Coke cans out of that one...even with FILLING the Coke cans I doubt they'd be as wet as the floor in that old hulk.
perryg114 04-19-2014 08:59 AM
It would be a great junk storage trailer. It might also be a good donor trailer. Looks like the end caps are intact and those are expensive pieces. The windows are still there as well as the door.
Perry
