-   -   Wiring Diagram please (http://www.airforums.com/forums/f37/wiring-diagram-please-11831.html)
Drifter 06-04-2004 06:17 PM
:confused: If any one has a wiring diagram that covers a 1970 Sovereign I would realy appreciate a copy. I recently purchased the above mentioned trailer and the preveious owner really screwed things up. I have managed to get most of the systems working, but have a few wires left over and my H2O pump isn't getting power and my controll panel doesnt work. Please help.
Thank you for your time,
overlander64 06-04-2004 07:21 PM
Greetings Drifter!
Welcome to the Forums and the world of Vintag Airstreaming!
Airstream didn't start publishing service manuals with the information you are seeking until 1972. It is a possibility that the 1972 may be similar enough to your 1970 that the service manual may be applicable. There is some wiring information in the owners' manual but likely not specific enough to address the issue with which you are currently dealing. You can purchase photo copies of the original manuals as described in the quote below from the Vintage Airstream Club web site:
Q: I need an owners and service manual for my Airstream. Where can I get one?
A: The first owners manuals were published in 1964. Prior to that, the owner received a brown envelope containing parts lists and other helpful information on the accessories in his trailer. The VAC has started making these available in the Members Archive section. A service manual with instructions for performing service operations did not exist until 1972.
You can get photocopies of owners manual (1964+) and service manuals (1972-1986) from:
Helen Davis Secretarial Services
PO Box 484 Sidney, OH 45365
(937)492-8885
Prices are about $33 and $70 respectively. After 1986 the Owners Manuals included available service information.
Good luck with your project!
Kevin
