-   -   window weatherstrip direction (http://www.airforums.com/forums/f164/window-weatherstrip-direction-116980.html)
rbn9 03-08-2014 02:05 PM
Hello
After many, many hours of scraping and deegooing all of the windows of the argosy aka "linda". I was just wondering which direction to stick down the new weatherstrip... for it is not quite the same as the old one...
A or B ?
please help. I would rather not go through this again, for at least another hundred years ;)
TAHNKS.
perryg114 03-08-2014 02:06 PM
A is the correct direction.
Perry
Inland RV Center, In 03-08-2014 05:30 PM
Originally Posted by rbn9 (Post 1425144)
Hello
A or B ?
TAHNKS.
There is a far better gasket for your windows that is hollow "D" shaped.
Most owners use it when replacing the gaskets, since it's also an upgrade, and does a far superior sealing job.
Andey
rbn9 03-11-2014 07:32 PM
window frame question
THANK's a lot for the help...
One last question ;) I am in the process of changing the old cracked plexie glass on the front window (the one between the 2 wrap windows) with a new tempered glass but can not pull the frame apart I chased out the rivets... but it seems to be glued or stuck...
please help
merci Ron
perryg114 03-11-2014 08:06 PM
It maybe stuck together. A heat gun might heat soften the bond but don't get crazy.
Perry
Inland RV Center, In 03-12-2014 08:50 AM
please help
merci Ron
There is a steel plate in the corners, that when it becomes rusted, it makes a super bond between the aluminum framing sections.
Most always, when that happens, you cannot separate the framing without damaging it.
If you have a broken window, make an insurance claim.
rbn9 03-13-2014 07:42 AM
window assembly
VICTORY :))
Thank's for all the help... With a chalumeau and some RUST CHECK✔ and lots of patience... et voila disassembly achieved.
Could not have been possible without removing the old plexie(window)...
merci... Ron
perryg114 03-13-2014 10:55 AM
Congratulations, you just earned your first Airstream restoration merit badge.
Perry
