-   Leaks - Weatherstrips, Gaskets, Caulks & Sealants (http://www.airforums.com/forums/f456/)
-   -   Sealants Summary ... (http://www.airforums.com/forums/f456/sealants-summary-116214.html)
TinTin 02-14-2014 12:08 PM
I've been reviewing the forums to determine which sealants to buy for water-sealing maintenance on my new-to-me Airstream. I've come up with the following list of sealants from the posts of others. If anyone has suggestions regarding these sealants, suggestions for better products, or sources for these products, I'd really like to hear them!!
For wheel wells/underbody:
Vulkem 116
Trempro 635
Roof
Silkaflex 721 White
Windows/Trim
Silkaflex 221 Gray
Parbond Gray or Clear
Small seams (between aluminum panels)
Acryl-R
truckasaurus 02-14-2014 12:21 PM
Hi Bob, I've bought stuff from VintageTrailerSupply; and in Canada Fastenal carries some as does a store called Cascade in Edmonton.
TinTin 02-15-2014 10:09 AM
I'm adding to the above list of sealants, based on the thread by sailorii which mentioned that Airstream now recommends AdSeal products.
Vulkem 116
Trempro 635
Adseal Premium Quality Sealant Gray (neutral silicone based)
Roof
Silkaflex 721 White
Adseal Premium Quality Sealant White (neutral silicone based)
Windows/Trim/Rubrail
Silkaflex 221 Gray
Parbond Gray or Clear (small hand tubes)
Acryl-R (small cans)
Alphonse 02-16-2014 07:42 AM
Tin, Thanks for the summary of current application and this should be very helpful to folks. Your work here is much appreciated.
This can be a tangle though since some of the caulks that were originally used are simply no longer available. For example I understand that Sikaflex 721UV Gray was used on the windows in the past but is no longer available from Sika but the white is. 721 is a silane terminated polyurethane and evidently has a large dose of UV stabilizer in it (good) for weathering resistance. These hybrid caulks (as 3M calls them) typically cost a bit more. I believe the demise of 721 Gray is what caused the factory to move to the Adseal about three years ago. From my research a couple of years ago, it was evident the Adseal is not a silane terminated polyurethane which makes it different than what is on my trailer.
So when working on my 2010, I try to assure compatibility when doing repairs and that causes a lot of digging for information on my part to be sure that what I put on top is going to be compatible with what is already there.
My perfectionist tendencies probably cause me to overwork this and I will also tell you that caulking is not a pleasurable past time for me and I want to minimize the frequency of rework!
TinTin 02-16-2014 07:51 AM
Corrected the sealants list again, based on info from Alan that Silkaflex 721 Gray is no longer available.
Vulkem 116
Trempro 635
Roof
Silkaflex 721 White
Alphonse 02-16-2014 07:57 AM
Tin,
The Sikaflex 221 that you had for the windows is available.
My point was that the 221 is just not the same as the 721. It is not a silane terminated polyurethane.
Sorry for the confusion.
TinTin 02-16-2014 08:04 AM
My mistake, Alan. :) Corrected the list.
Vulkem 116
Trempro 635
Roof
Silkaflex 721 White
Silkaflex 221 Gray
chilipepper 02-19-2014 09:56 AM
Thanks for the list and this will be a great resource. Since we are still in the middle of winter up here I'm wondering what temperatures these can be applied in as well as maybe an ideal application temperature? I have a couple of projects that could use some of these sealants and the daytime high temps here are barely touching freezing. Can I still effectively use any of these or do I need to wait for warmer weather?
TinTin 02-19-2014 01:04 PM
I'm far from expert in this chilipepper, but I'd wait until the temperatures are at least 50F. I've checked a couple of tubes of silicone II that I have here, they say 5C before application (about 40F). The acrylics and polyurethanes probably want temperatures higher than 50F to insure that the products are pliable enough for easy (and tidy) application.
Airtandem 02-19-2014 04:00 PM
I just got my "Capt. Tolley"s Creeping Crack Cure" that was suggested in another thread to seal the rivets.
TinTin 02-19-2014 07:00 PM
Added rivet sealer based on Airtandem's post:
Vulkem 116
Trempro 635
Roof
Silkaflex 721 White
Silkaflex 221 Gray
Rivet sealer
Captain Tolley's Creeping Crack Cure
acstokes 02-19-2014 07:57 PM
I've used these products with good success:
LOCTITEŽ PLŽ S30 POLYURETHANE ROOF & FLASHING SEALANT
Loctite PL S30 Polyurethane Roof & Flashing Sealant from Loctite Adhesives
LOCTITEŽ PLŽ S40 POLYURETHANE WINDOW DOOR AND SIDING SEALANT
Loctite PL S40 Window Door and Siding Sealant from Loctite Adhesives
They're both polyurethane. They take a couple of days to dry (cure) though, so apply when the weather is expected to be fair.
BAB 02-19-2014 08:04 PM
This is such a great post! I've printed it and will keep it handy....I keep a supply of Parbond, Silkaflex, Vulkem and Trempro handy. Also a roll of butyl tape that I've used on a couple of occasions. A spray can of the Pewter touch-up paint also comes in handy.
jakes_mama 02-19-2014 09:10 PM
As an owner of a vintage AS (1965), are these sealants also recommended? If not, any recommendations?
TinTin 02-19-2014 09:36 PM
Added the Loctite sealants based on acstokes recommendations.
Vulkem 116
Trempro 635
Roof
Silkaflex 721 White
LoctiteŽ PLŽ S30 Polyurethane Roof and Flashing Sealant
Silkaflex 221 Gray
LoctiteŽ PLŽ S40 Polyurethane Window Door and Siding Sealant
Rivet sealer
TinTin 03-10-2014 09:22 AM
Added exterior lights to group 4
Vulkem 116
Trempro 635
Roof
Silkaflex 721 White
Silkaflex 221 Gray
Small seams (between aluminum panels)/Exterior Lights
Rivet sealer
TinTin 10-07-2014 03:38 PM
Added Dicor to roof sealants
Vulkem 116
Trempro 635
Roof
Silkaflex 721 White
Dicor self-levelling sealant
Silkaflex 221 Gray
Rivet sealer
BoldAdventure 11-15-2014 06:52 PM
Great thread Bob, very useful for a newb.
Swahealy 11-26-2014 01:55 PM
This is so helpful TinTin. Thanks so much for posting
TinTin 12-04-2014 05:42 PM
(removed LocTite PLS30 from roof sealants)
Vulkem 116
Trempro 635
Roof:
Silkaflex 721 White
Windows/Trim/Rubrail:
Silkaflex 221 Gray
Small seams (between aluminum panels)/Exterior Lights:
Rivet sealer:
