-   1966 - 1968 Safari (http://www.airforums.com/forums/f192/)
-   -   1968 Safari Deadbolt (http://www.airforums.com/forums/f192/1968-safari-deadbolt-114526.html)
DFlores 12-31-2013 01:47 PM
Can anyone offer a solution for my missing deadbolt?
I have an L100 door lock, and the mounting in the door frame for a deadbolt, the existing L100 cannot be locked from the inside. Need a deadbolt that can lock from inside or Diana will never sleep in the trailer.
From what I've read, the original deadbolt only unlocked from inside
Any help would be greatly appreciated
sarasafari 12-31-2013 02:21 PM
I am not ANY kind of expert on Airstreams, but I do have a 1969 Safari, and it never had a deadbolt. I am going to take it to a shop to get one installed, before I camp, though.
HowieE 12-31-2013 02:42 PM
What I used to keep the grand kids from falling out the door was a simple double hung window sash set on the screen door. That will lock them out.
DFlores 01-01-2014 10:33 AM
Sara, let me know what lock your shop comes up with, I have been looking thru the normal sources and come up empty
DFlores 01-01-2014 02:38 PM
We came across a deadbolt that may work at Vintage Trailer Supply - VTS-343C
Will report back if this works....unless someone who has tried this in past can save me the purchase price and tell of their success or lack there of
DFlores 01-02-2014 09:30 AM
Finally looked at VTS deadbolt on my "big" computer and could see that it mounts on wall next to door, these mobile little screens have limitations, would still like to hear from someone with a door mounted solution
ALUMINUMINUM 01-02-2014 02:25 PM
Dear Diana and Dave,,
The L-100 has its own, built-in locking mechanism. When functioning, it clicks locked when turned in the opposite rotation from open. Rebuild kits are $50 on eBay.
Un-skinning and re-skinning the door is no fun. There is wood reinforcement to remove where the dead-bolt goes.
A dead-bolt will not prevent entry into the trailer. One simply has to push in the little lower “stack” window by the door, reach in and unlock the door. While a keyed on both side dead-bolt would work better for unexpected nightly invasions, it hampers emergency egress, and not recommended by firemen.
Perhaps it's false hope to presume that they can read, but when away, I leave a note to thieves/vandals in the stack window with instructions to break-in this way so as to prevent damage to the door and jamb from prying tools.
An outside keyed dead-bolt's best use is to prevent the suicide door from opening while traveling.
DFlores 01-02-2014 05:07 PM
I had kind of had been figuring it was something like that, I did try turning the "wrong" way from the inside.
We just replaced insulation in the door and replaced the wood reinforcing.
Thank you very much for the guidance, Next we will get a rebuild kit, I did have a time making the door knob work after "carefully" dropping all the insides on the floor when I was removing the knob
Maybe It didn't go back completely correct?
ALUMINUMINUM 01-02-2014 05:42 PM
I'd guess that there is an exploded view diagram online somewhere. I think that there are you-tubes of it also.
Mine makes me nervous. I disassembled, cleaned and lubed. It works best if the two screws that hold the inside knob escutcheon are not tight. This really bugs me.
It isn't a marvelously engineered lock-set, and the material/workmanship doesn't impress. They are scarce, that's why they're expensive.
I don't know if the rebuild kit has all the parts, someone on this site has more knowledge about the L-100.
Sadly, we're stuck with them.
LouiesRV 04-22-2014 03:19 PM
VTS Deadbolt
Our '67 had a deadbolt. Not sure if it was original or aftermarket, but the PO lost the key and had to break it to get the door open.
I installed the VTS deadbolt in the door. I had to remove most of the rivets from the upper inner panel of the door to access it. I didn't have to remove the outer skin at all. It comes with a 3/8" round rod threaded into the bolt which goes into the door frame. I had to revise the setback a bit to get it to fit the hole in the door, so I made a new rod by cutting the head off of a 3/8" SS bolt.
It works great, better than the replacement handle lock, which I can unlock by jiggling the handle a few times.
Zadiegirl 04-22-2014 06:30 PM
I have been looking for locks too. I have a deep set back 66 Overlander.
My quest has led me to Weiser locks. They make a 5" dead bolt. I think that I am going to try to have some cut the bolt to fit. I don't know what else to do either.
Inland RV Center, In 04-22-2014 07:01 PM
There is a lock kit available that replaces the L-100.
The nice thing about that kit, is that it has a built in dead bolt.
bsaa10bill 09-01-2018 09:34 AM
What did you finally do about a lock? I have the original on my 68 safari and I'd like something more secure. Thanks
JRF0st3r 09-03-2018 09:43 AM
deadbolt
bsaa10bill,
There are other solutions but what we did was to get the deadbolt with extended bolt from VTS that mounts in the frame next to the door. This was done while the interior skin was off. We added some wood blocking for a more secure mount. Getting it to work smoothly required some grinding of both the bolt and hole in the door but now it works great.
Rhino33 10-02-2018 02:09 PM
Andy - Do you carry the replacement lock for the L100 with the integrated dead bolt?
Thanks so much!
Bubba L 10-02-2018 03:08 PM
Thanks so much!
Don’t think Andy is still with Inland. You may try Dan Piper at Vintage Campers.com. I think they have parts for the L100 lockset. Good luck, Bubba
montanablue 10-02-2018 08:31 PM
I have new and used Bargman L100 or L200 and the OEM Bargman Rebuild Kits for L100/200 locks. I can rebuild your lock with all of the spare parts I have. Keep in mind Airstreams require the longer throw, stem or latch. I have a new one for sale that is ready to stall. You can reach me at r_whiten@hotmail.com or send me a private message. I will be glad to help you.
Rick (Montanablue)
montanablue 10-02-2018 08:36 PM
Pictures of new Bargman L100 lock with long stem.Attachment 324313Attachment 324314
Rhino33 10-09-2018 02:30 PM
Thanks so much for the information - as well as the availability of a replacement/repair. I will need to take a photo of our doorset, as I think there may be a dead bolt underneath the AS lock. And of course, all of the photos I have taken so far have the door open! OIY! I'll check on it tomorrow and advise.
Thanks, again!
Rhino33 06-04-2019 02:37 PM
Fantastic Lock Contact!
We just wanted to give an extra thanks to MontanaBlue (Rick) for the several conversations, photos, explanations and suggestions he has had with us. If you are in the need of a replacement lock or a rebuild kit, we highly recommend contacting Rick directly. While we have met so very many helpful folks here on the forum, Rick was high on that list. Very friendly and willing to talk through our situation (as each trailer has her own idiosyncrasies) to be sure we figured out a resolution.
THANKS RICK!
