-   -   Aluminum F150? WHOA! (http://www.airforums.com/forums/f463/aluminum-f150-whoa-114383.html)
ROBERTSUNRUS 01-13-2014 10:01 PM
:) Hi, don't under-estimate the strength of an aluminum body.
True story: I was once a Mac Tools distributor. [eight years] My truck was a GM P-30 with an all aluminum Grumman Olson body. One day while I was eating lunch, some lady ran into my parked truck. There was some rear bumper damage [also aluminum] and the left rear quarter panel area had a huge bend in it. The damaged area was a triangle of about 18"s of flat aluminum panel. It was sort of curled out ward. I took it to a few body shops to see if they could repair the bent aluminum panel. I was asked by the body repair man if it was hardened aluminum or not. I had no idea, as I have never heard of hardened aluminum before. The body repair man walked out to my truck with a long handle, ten pound sledge hammer. He swung the sledge hammer at the bent aluminum panel in a direction that would bend it back towards where it originated. The aluminum didn't budge and the hammer came back and almost hit him. The bent piece of panel was cut off, heated, pressed back into a flat panel on a huge hydraulic shop press, welded where it cracked during the straightening process and finally welded back onto my truck. The car that hit my truck had the whole right side ripped off.
Rust 01-13-2014 10:42 PM
Aluminum
Funny thing is people do under estimate the strength of aluminum, also people don't know how long Ford has worked on this plus do you not think GM and Chrysler are not going the same way.
Steel companies are always trying to come up with lighter steels to compete with Aluminum.
Check out a frame from 10 years ago to a frame made today and see which is stronger and lighter.
The technologies in heat treated steels and hydro formed frame rails has come a long way in the last 15 years.
And if a panel get's damaged then do like I did on my air stream get it fixed and move on.
And yes I do see the fiber carbons being the next ones on the market.
Not to mention Aluminum will have different treatments done to prevent corrosion.
This new truck is a sweet looking truck and just in time for me to replace mine.
DKB_SATX 01-13-2014 11:19 PM
On the intro to his show tonight, Stephen Colbert mentioned that "the new Ford F150 is 93% aluminum." He didn't point out that the percentage just relates to body panels, but I thought it was a funny non sequitur for his show.
Skater 01-14-2014 07:08 AM
Apparently they're looking for people to test them. I'd like to submit an application.
"I would like to take the F-150, hook up our 30' Airstream, and tow it to Cumberland, Maryland for a weekend. When we did this last year, our 2006 F-250 6.0L diesel blew out much of its coolant on Sideling Hill. Let's see how the F-150 handles it."
Too bitter?
lsbrodsky 01-14-2014 08:11 AM
Un-American
Seems un-American to not offer a V-8 in a full-size pickup truck....
Larry
HeadWest 01-14-2014 08:14 AM
Larry
They do. The 5 liter is still available, just not the 6.2.
kscherzi 01-14-2014 08:14 AM
" No specific tow rating or payload figures have been released, but Ford has revealed a few things.
All maximum tow ratings and payloads will rise from last year because of the reduction in vehicle weight. The 3.5-liter EcoBoost V6 was rated at 11,300 pounds last year.
The new 2.7-liter EcoBoost will be good for about 8,000 pounds of towing capacity, a useful figure that plugs a hole between the entry-level V6 and the 5.0-liter V8. Last year these were able to tow roughly 6,000 and 10,000 pounds, respectively.
All 2015 F-150 tow ratings will be certified to the new SAE J2807 standardized tow rating procedure. The Big Three have previously been reluctant to adopt this standard because it would result in a loss of about 300 pounds of capacity and no one wanted to blink first. This time Ford is confident it has made enough gains to overcome this and still maintain or extend its advantage over the competition."
The increased payload will make the truck a viable alternative to the F-250.
Sent from my Nexus 7 using Airstream Forums mobile app
dznf0g 01-14-2014 08:18 AM
From what credible source did you hear that Ford will move to J2807 with their introduction of the new F150? Our intel says otherwise...but there could be some "hoodwinking" going on.......
Help me out here, please reference your source, please.
DKB_SATX 01-14-2014 08:56 AM
He's quoting the Edmund's article to which I linked in a post yesterday.
I missed the J2807 reference when I first read the Edmund's article Sunday night, I think that's great. I expected Toyota's adoption to drive the change faster, but GM and RAM released new trucks without mentioning the test... If Ford can exceed their competition's marketing numbers with J2807 numbers, it may finally push the others to play ball.
dznf0g 01-14-2014 09:03 AM
Thanks, The author doesn't cite a source per say. Interesting though, since there was some gentlemen's agreements sort of in place to accept all at the same time....but, like I said, hoodwinking does occur. I'll pass on and I guess we'll see how it pans out.
Jim Clark 01-14-2014 12:37 PM
Originally Posted by wahoonc (Post 1396658)
My 1967 MBG-GT had an aluminum hood... got replaced with steel after it the latch failed and it wrapped back over the top of the car.:sad:
Aaron:cool:
My 58 MGA has aluminum Hood/Bonnet, doors, trunk. My TR3 and TR6 all steel. I don't know about the older models. I will be ready for a new truck in a couple of years, go Ford.
mojo 01-14-2014 02:53 PM
More info...
Ford Just Unveiled It’s New F-150 Truck and It’s Being Called ‘Radical’ | Video | TheBlaze.com
graysailor 01-14-2014 03:59 PM
Ford is having problems with the Aluminum and are hoping to have matters worked out in time for the 2015 model year. They are working with Alcoa. Should be a great weight saver which will contribute to increased fuel milage. Aluminum is also easier to shape into the panels that they will be using. Should be no structural difference but I am hoping that they stick to steel for the frame.
WineStream 01-14-2014 07:29 PM
You guys got me all excited... I'll be at the auto show in Detroit for the next two days. I'm going to have to hang out by this truck for a while and check it out.
-sent from the Airforums mobile app
