-   Awnings (http://www.airforums.com/forums/f442/)
-   -   Can anyone identify this awning company (http://www.airforums.com/forums/f442/can-anyone-identify-this-awning-company-111755.html)
DMM 10-20-2013 07:36 PM
Hope this works first try
Any help would be appreciated.
David
<a href="securedownload1_zps54fb42b3.jpg Photo by dmmilesp | Photobucket" target="_blank"><img src="http://i854.photobucket.com/albums/a...ps54fb42b3.jpg" <a href="securedownload1_zps54fb42b3.jpg Photo by dmmilesp | Photobucket" target="_blank"><img src="http://i854.photobucket.com/albums/a...ps54fb42b3.jpg" border="0" alt=" photo securedownload1_zps54fb42b3.jpg"/></a>border="0" alt=" photo securedownload1_zps54fb42b3.jpg"/></a>
eubank 10-20-2013 08:01 PM
David, in order for folks to be able to see your photos, you'll need to use the image code appropriate for Airforums:
Airstream Forums - FAQ: Reading and Posting Messages
Lynn
DMM 10-20-2013 08:10 PM
Lynn
I clicke on the link and it showed pictures or am i the only one that can see them.
DMM
PhilipKS 10-20-2013 08:12 PM
I can see them when I click on the links. Can't help identify, however. Welcome to the forums!
eubank 10-20-2013 08:15 PM
I think David was probably trying to display the pictures directly in AirForums. The code he's got is the html sharing code provided by his photo hosting outfit, but it's not the code that will display pictures directly within AirForums.
Lynn
Splitrock 10-20-2013 09:31 PM
I see the pictures fine. I can't answer the awning challenge though.
overlander64 10-21-2013 07:02 PM
Can anyone identify this awning company?
Greetings David!
Welcome to the Forums and the world of Vintage Airstreams.
David
I suspect that you may have an awning that a previous owner has assembled from miscellaneous parts. The pieces of the awning tube tension springs as well as the awning tube ends appear to be A & E, but the awning arms aren't like any that I have ever seen on an A & E product. The wood piece that can be seen in one of the awning tube end photos initially gave me the idea that it may be an awning "built" from parts salvaged from multiple awnings. Falkner (not positive about spelling) made awnings for travel trailers during the 1960s and 1970s, but I am not certain whether any of their awnings had profiles similar to yours.
Good luck with your investigation!
Kevin
DMM 10-22-2013 06:00 AM
Thanks Kevin!
I will check out A&E.
David
