-   -   Vista View window repair/replacement (http://www.airforums.com/forums/f454/vista-view-window-repair-replacement-1113.html)
83Excella 07-16-2002 10:46 PM
This is a link to a vista view window repair and replacement page. (All credit goes to the site owner)
http://home.att.net/~n7kt/vview.html
Hawk5274 02-04-2013 05:13 PM
Hello John,
One of my overhead Vista windows just shattered from the cold freeze and thaw or moisture although I never saw any leak to the interior. I have plugged the broken window by shaping Styrofoam and tape until I find a replacement. I have a 70 Overland sovereign 31'
My question is the overhead vista seems to have a curve. I see some replacements on ebay. But kinda chicken to attempt replacement, drill out pop rivets, put new window in just to find the holes don't match up. How hard is the replacement? Your link is not getting me to the link, showing error.
KenSanLan 02-17-2013 06:15 PM
Hi, all. I am confused - we have been under the impression that these windows were no longer available and could not be replaced, only repaired. We own a 1976 31' Sovereign - are the 1970 windows different from 1976?
perryg114 02-17-2013 06:53 PM
You can replace them with a new single pane version.
Perry
Inland RV Center, In 02-25-2013 12:32 PM
The difference was the early 70's windows were single pane.
The later 70's windows were double pane (the ones that cause most of the problems).
Hawk5274 02-26-2013 03:32 PM
Haven't replaced yet. But ready to do so. The windows I have in the 70 airstream is a one pane 1/8" version. Nd it exploded to the outside , ah, had to pick-up all the glass outside the camper from freeze and thaw. Duck tape and Styrofoam still holding strong for now. Going to Bell Center very soon. $450.oo dollars to repair one window..........
Hawk5274 02-26-2013 03:33 PM
D o Not close the inside shades when the temps outside are below freezing!
Inland RV Center, In 02-26-2013 03:45 PM
Which window are you replacing?
KenSanLan 03-01-2013 04:59 PM
Andy - we have the double paned windows in our '76. Can they be replaced with new single paned windows?
Inland RV Center, In 03-01-2013 06:00 PM
Yes, the can.
dziminski 03-07-2013 08:58 PM
Vista windows
Originally Posted by Inland RV Center, In (Post 1267432)
Yes, the can.
I have a 73 Airstream with the vista windows that are dual pane. They all look bad because of the moisture between the panes. I'm wondering if the inner panel is plexiglass not glass. If so can I just break out the inner panel rather than replacing each one?
Thanks Dick
dziminski 03-07-2013 09:00 PM
Thanks for the quick reply!!!!!!!!!!!
Joebanjo 05-10-2013 12:06 PM
What do you intend to do with your double pane take offs? I rebuilt all mine to single pane versions with no problems. If you are going to trash them...let me know, I might buy them from you, rebuild them, and resell.
Mixter 06-05-2013 10:34 PM
Joebanjo- what's your preferred method of rebuilding the '76 double pane vista view?
Thanks!
Micky
Hawk5274 06-06-2013 06:38 AM
I considered my time into the equation along with attempting to get the right fitting window, hard to find. And the 56 pop rivets, gaskets, silicone? I have taken my wagon up to Jackson Center, Ohio and let the Airstream factory replace it. It is still up there but being kept inside out of the rain waiting on the proper window to be installed. I had a 5 week window to get the window in before we have plans to hit the road for vacation. If I did the replacement I wouldn't be sure I could prevent leaks or even break the new window while pop riveting it in, which kill campers so off to the factory I went.
