-   -   Interior Flouresent lights to LED PUCK (http://www.airforums.com/forums/f447/interior-flouresent-lights-to-led-puck-108148.html)
J&G22argosy 08-05-2013 07:46 PM
We are remolding a 1990 29" Excella, and currently have the 2 bulb flouresent interior ceiling lamps with a On-Off switch on each on. We want to remove these and replace with the new type LED PUCK lights.
Can these LED PUCK lights be controled individually by an On-Off switch also?
Or is there any recomendations?
J&G
So. Miami, Fla
cwf 08-05-2013 09:41 PM
5 Attachment(s)
J&G
So. Miami, Fla
I removed fluorescents and installed LED rectangles
Attachment 192527
I tied them to a wire mesh called "hardware cloth".
Result is awesome. Plenty of light and low battery draw.
Here was a previous application using strip LED but they were too Hot!!! Probably around 6000k instead of the 5400 they claimed to be.
Attachment 192528
I would fit in with the "close encounters of the 4th kind" had I kept those!
Attachment 192529
Don't forget. You remove the transformer then connect lights to the DC supply wire.
I also used a LED driver to dim the LEDs
Attachment 192530
Attachment 192531
J&G22argosy 08-07-2013 07:08 AM
LED's
Thanks for the idea, your interior looks awesome with those LED's! But I want to get the look of the newer models, with the small Puck type LED's.
J&G
HowieE 08-07-2013 08:29 AM
I bought 2 rolls of 16 ft LED strip on E Bay and replaced every light in the trailer. The strips can be cut in 3 in increments. I used 3 sections in the 4x4 fixtures and 3 an 4 12in. strips in the large fixtures with the 3 sections controlled by the low side of the light switch and all controlled by the high side of the switch.
Rolls are currently selling for about $10.00 a roll.
Yes the color is a bit higher than the original lights but fine.
TinShack 08-07-2013 08:47 AM
J&G
So. Miami, Fla
Are you planning on recessed or surface mount? I have surface mounted ones over my dinette and those have switches. It may be more difficult to find recessed lights with switches. Also, if you can't find them in LED, you can always buy halogen and replace the bulbs with LED's.
PapasRV 10-05-2013 08:35 PM
LED Fluorescent Tube Replacements
I've used the Cabin Bright in all my fluorescent fixtures and they've worked out quite well. And even more important my wife is happy!
