-   -   ProPride installation and setup instructions PDFs? (http://www.airforums.com/forums/f464/propride-installation-and-setup-instructions-pdfs-107144.html)
Alphonse 07-13-2013 09:41 PM
I did a search tonight without success to find a PDF or other electronic files for the installation and setup of the 3P ProPride hitch. Do they exist in electronic form?
I did find blogs and photos of the setup process but I am looking for the manufacturer's documents.
SteveSueMac 07-13-2013 10:38 PM
I know there is - I have a PDF of it on my iPad but I don't remember where I downloaded it from!
Anything in particular you're looking for?
PharmGeek 07-13-2013 10:52 PM
I'll get it to you - I have it in email
PharmGeek 07-13-2013 10:54 PM
https://dl.dropboxusercontent.com/u/...0Operation.pdf
SteveSueMac 07-14-2013 06:12 AM
Thanks, Pharm!
BlueMesa 11-30-2014 11:22 AM
PharmGeek,
Do you have satellite external antenna on your AS?
I have the port on the outside, but I'm not sure where it comes out on the inside. I'm hoping its not behind the TV as I'm not sure where one would mount the receiver.
Thoughts?
BlueMesa
rmkrum 11-30-2014 11:56 AM
Thanks for the PDF!
ghaynes755 11-30-2014 03:22 PM
Blue the other end of the sat cable should be in the cabinet with the BluRay player. Usually you need to slide the BluRay out and then fish/look/curse on how to get it up and out so that you can connect it to the RX.
BlueMesa 11-30-2014 03:33 PM
Ok. Got it.
DeltaRon 04-21-2015 09:01 AM
Greasing ball on PP
My PP was installed by dealer. I'd like to verify they greased the ball, but can not find instructions on how to lift PP head off in ball. Can someone give me instructions? I emailed PP but no response.
rmkrum 04-21-2015 05:50 PM
Slack off the WD bars a bit. You can then place a small jack under the PP head, take the slack out, then unlatch the trailer coupler like normal and ease the small jack and head down slowly. Keep the tongue jack up high for clearance to work. You don't have to disconnect WD bars or the yoke.
You may have to wiggle the head fore and aft a bit to disengage the PP ball from the trailer coupler.
Noggin 04-21-2015 07:14 PM
Holy smokes Al, are you finally going to put that thing on?
Joe
Dlbriggs 09-19-2017 11:50 AM
The link to that document seems to be broken. Is there another link available?
james.mileur 09-20-2017 06:06 AM
Look through the "unofficial Pro Pride" thread for some good install and operational tips.
