-   -   Bedroom TV issues (http://www.airforums.com/forums/f44/bedroom-tv-issues-105574.html)
snickers 06-05-2013 04:31 PM
Bedroom TV issues
have a 03 land yacht, has a rear rv enclosed in a case mounted to wall.
Issues are
1. have a Jack antenna with digital stream boxes, one for front tv and one for rear. Front TV works fine, rear one will not find any channels. I have pulled out the TV checked the connections, all tight and the green lite on the digital stream comes on fine. any suggestions. both tv work fine connected to cable.
2. due to TV being pulled out, can't get the screws back up into the metal plate that is mounted on back of TV, any secrets to line them up? Can't see in there, can't lift/shift TV at all, it is tight.
Enjoying life the way it should be , on the coast of Maine!
