-   LP Gas, Piping, Tanks & Regulators (http://www.airforums.com/forums/f287/)
-   -   Propane Line quick release valve set up (http://www.airforums.com/forums/f287/propane-line-quick-release-valve-set-up-102854.html)
fmacmaster 03-27-2013 07:26 AM
Does anyone know if the Propane line going to the quick release valve on the trailers thong is before or after the regulator on the LP tanks? Looking get a longer propane line to hook up to the grill which has a regulator. If the line on the Airstream is on the after side of the regulator. That would be double regulated. Not Good.
dznf0g 03-27-2013 07:31 AM
It is after the regulator. Mine, of course, didn't have a hook up at all so I obtained high pressure bits and pieces, mostly from McMaster Carr, and run high pressure to the grill, and portable gas fire pit.
