-   Upholstery, Blinds, Walls & Interior Finishes (http://www.airforums.com/forums/f39/)
-   -   Curb side galley window (http://www.airforums.com/forums/f39/curb-side-galley-window-10046.html)
pipsmith22844 03-16-2004 09:55 AM
I am in the process of making a roman shade to cover the window over the sink in the kitchen. I am using an old blind mecanism without the blind pieces but only the strings in the top bar for raising and lowering the blind. I am using material that we used to recover the goucho. I want to use velcro to attach the curtain to the blind cross piece so that I can remove the curtain for cleaning when necessary. I glued some on with Elmer's glue but when I pulled the curtain off the glue did not keep the hook side of the velcro on the bar. Are there any suggestions for securing the velcro to the plastic rod?
Thank you for your help.
smily 03-16-2004 10:10 AM
Contact cement
Follow directions on can.
This stuff is gooooooood
Smily
