Old 10-03-2009, 10:13 AM   #1
flyrc's Avatar
1962 22' Flying Cloud
Yakima , Washington
What did this drip cap cover '58 Overlander
Is there supposed to be a louvered vent in the area where the patch has been placed? It looks like someone may have added the roof vent later. If not, the factory wasn't worried about appearance. There isn't a gas line in the interior so I'm guessing that the refrigerator wasn't gas/electric.
Name:	Frig vent  maybe.jpg
flyrc is offline   Reply With Quote
Old 10-03-2009, 02:46 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
One should be for the furnace, and one for the fridge. Looks like the vent for the fridge was relocated at some point.
Old 10-03-2009, 03:20 PM   #3
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
A window... I saw a pic of a 59 Custom Overlander that had a window like that. Now if I just remember where. An early vista view I guess. I would be nice if you could find a replacement window for it.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 10-03-2009, 04:09 PM   #4
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
That fridge vent looks original to me but I don't know about the patch. That sure is strange. Also, I'd check the floor under the fridge area for a hole for the gas line as a PO may have removed the gas line but a hole in the floor near the back would tell the correct tale.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 10-03-2009, 07:32 PM   #5
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Hi Flyrc:
The patch might have covered a window above an original ice-electric Marvel fridge, similar to the window on the earlier FC pictured here:
http://www.vintageairstream.com/arch...s/curbside.jpg
and the fridge seen here:
http://www.vintageairstream.com/arch...des/fridge.jpg
Is there any evidence inside the trailer that a short Marvel ice-electric fridge used to be there?
I have not seen many drip caps above added-on flat vents for fridges, so think that hole originally was a window. Then again, maybe a former owner at first replaced the old window with a rectangular louvered fridge vent but didn't like how it worked, so had the Calif. factory add a long oval roof vent for a propane fridge. Then perhaps he patched over the old window/rectangular vent as the new roof vent made the old vent obsolete.
The long oval vent on the roof above the patch is a California style fridge vent. It's presence there suggests a propane fridge was installed at some time in your trailer.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 10-03-2009, 11:20 PM   #6
flyrc's Avatar
Yakima , Washington
Thanks for the great links and the info on the California trailer vents.
Wally H.
Parts needed
1962 Street side corner tub
range or parts
Dometic 50 or parts
